Audio System Upgrade Thread 04 Tahoe
04whitetahoe
04whitetahoe
TYF PLUS!(tm)
Lincoln, Calif
....a 1000W Incriminator LI retails for around $275
That 750 would push an Incriminator Lethal Injection series, DD 2500 series, of a SSA GCON very nicely.
As far as sealed vs ported goes...
http://www.diymobileaudio.com/forum...y/159125-audio-x-inc-project-black-build.html
Hey Daniel, Thanks for the suggestions regarding the Subwoofer. I've decided to go non-ported enclosure, but have not yet decided on a Sub, so this will be helpful as I research what I will get.
Joe
HortonHiresAHoe
Mt. Juliet, TN
No problem. Below are some great resources, but be very careful... that's a rabbit hole that's hard to come back from :) I started off wanting a simple 10" kicker CVR in a console powered by a zx400.1 that I already had, but quickly spiraled outta control! The components alone are twice as much as I intended to spend on the whole setup.
caraudio.com - slanted more toward spl
diymobileaudio.com - those guys are all about sq. Some of the installs in their "Build Logs & Project Install Gallery" are simply amazing. The SQ stuff is waaaaayyyyy outta my budget tho
store.soundsolutionsaudio.com/ - best pricing I've found w/ free shipping and great forum
Good luck and keep us posted!
04whitetahoe
04whitetahoe
TYF PLUS!(tm)
Lincoln, Calif
Ordered Sub Today
Just ordered my new sub:
SA-12 D2 - Sundown Audio 12" 600W Dual 2-Ohm SA Series
Now to learn about sub boxes and get the right one as well as get my order in to KnuKonceptz for my wires and I SHOULD have all I need for my sound!!!
OH YEA!!!!
:headbang:
YukonXL04
The Riverboat
Arlington, TX
Sweet, Congrats man. What kind of box are you thinking?
http://www.sundownaudio.com/index.php/products/subwoofers/item/sa-series.html
Go there and download google sketchup and then download their file for the single 12, it has a 3D view of the box also has the cut sheet for each piece of wood.
Wish you were closer, I would like to hear that sucker next to my RE, curious how it sounds.
04whitetahoe
04whitetahoe
TYF PLUS!(tm)
Lincoln, Calif
Sub Box Suggestions???? F3 of 46Hz
Hey Shawn, Don't want to build my own.
Looking at this box that is close to the speaker spec which is
Recommended Box Specs (Sealed): 1.0ft^3 (Yields F3 of 46Hz)
Any input?? At 1.1 Cu Ft, this is the closest I can find to what my speaker spec wants.
No mention of F3
http://www.sonicelectronix.com/item_62462_Ground-Shaker-CP-1-12-GRAY.html
Nice!! Should sound amazing.
Thanks!
Any speaker box suggestions?
I can't seem to find any specs on pre-made speaker boxes that reference the F3 of 46Hz, only the cubic Ft. volume.
Any good boxes besides Ground Shaker?
:boti:
YukonXL04
The Riverboat
Arlington, TX
The specs are just telling you what the f3 is if used in that box size...
Honestly I would run ported
04whitetahoe
04whitetahoe
TYF PLUS!(tm)
Lincoln, Calif
Hey Shawn,
I've read that ported is more for rap Boom Boom music and it's not "as clean" of a bass sound as sealed.
Also that and sealed is more for rock, jazz and such. I like classic rock.
Is that not true? Why do you like ported?
:cheers:
YukonXL04
The Riverboat
Arlington, TX
It really depends on the sub. I have had different results with different subs, It also depends on the tuning of the box, the most common problem I would say with ported boxes is a humming sound when it hits certain higher notes. Tell ya what, Call up sundown and tell them your sub/amp and music preference and see what box they recommend.
For example I partially bought my sub to go in a sealed box, the specs show that it can be used so I went with it. When I was done I called RE's tech support and he strongly recommended me trying a ported box. He said while they show their subs can run sealed, they are meant for ported applications.
As far as the ported for rap, sealed for rock debate. It really comes down the the subwoofer, that sundown should be a great sub. I would expect good sound quality from it in a ported application.
I am running mine in a 1.0 cu.ft. after displacements ported box tuned to 34hz. For me thats a little high, my next box will be tuned to 31hz. But all in all I am extremely surprised how it sounds in a ported box. I listen to a variety of music. Rap, Country, Old rock, New rock, and some in between stuff as well, so I needed something versatile. This does it for me.
HortonHiresAHoe
Mt. Juliet, TN
SA series will sound good sealed but were really designed for ported enclosures. With a properly-built & tuned ported box, the sa will have greater efficiency with a more controlled response. The sealed for rock, ported for rap myth is just that. It's all in the box... a great sub will wound mediocre in a junk enclosure and a mediocre sub can sound great in a nice box.
You can fit a ported box for a single 12 in the quarter panel area
Keith49
