How to do the 4 or 6 high mod on an 03-06 full size truck for $3.00
bigbird189
So I have done this before with the 3 amp 50 volt diode on an old denali but have since sold it and bought another denali, but this time I went to Radio shack, all they had was 3 amp 200 volt and 3 amp 400. Can I use any of these? Or should I wait until I can find 3 amp volt again?
scoobyxj
Nope they will work just fine. The amperage rating is how many amps can be safely pulled through the diode, and the voltage rating is the max voltage it can handle. The relays pull less than .5 amps, and the voltage is 12-14.8 so anything rated higher than that you are good to use...
bigbird189
Thank you. I just installed these last night and freakin love this mod.
Ddbell21
Little rock
Just did the mod today took me about 15 minutes to do. Using th hammer to flatten the ends really does help. Amazing write up.
I just read every post in all 13 pages and now i'm so confused...lol Can someone remind me how to get the fogs on with auto low beams? not interested in anything to do with highs.
Thanks!
Grimes
Thanks!
If you do the above, which is much more involved, you will have auto fogs with the auto lows, but also the ability to turn on and off the fogs. If you do not care about turning them off and want them on whenever your lows are on, simply do the following:
In that image, just do the wire that is towards the bottom of the image. It links the low to the fog, so whenever the lows are on, the fogs are on. Be sure the diode is facing the correct direction.
So that is a simple diode from HDLP-Low 85 to FOG LP 86.
bigbird189
Just make sure, shouldn't the direction of the diode go the other direction in the pic? Since the low will power the fog? I mean I don't know much about which direction for diodes but when I did high 6 they both went with grey part furthest away from low. Just want to make sure it's the right direction.
Grimes
Well, look at it. The high is powering the low when the highs are on, so the grey is on the high end. The lows are powering the fogs when the lows are on, so the grey is on the low end.
Done the opposite way as you suggest, the lows would come on with the fogs. If you're using fogs, your lows are probably on anyway due to the sensor. So it is redundant. However, this results in what I was trying to avoid, which is the need to turn the fogs on at start up every time. With my setup, when my lows are on, my fogs are on. When highs are on, lows are on, thus fogs are on.
bigbird189
Ok thank you I understand now. I was just curious. I will do the same today!
NeverSatisfied
eBay Baller
Wichita, Kansas
Just want to throw a shoutout to Grimes. Hardest part about it all was getting that low beam relay back in lol I now have auto fogs with the lows and didn't have to splice into anything and can be removed if(which not probable) I sell the vehicle
Grimes
Glad to hear it went well. And I agree, the hardest (and honestly the most concerning) part was taking a set of pliers to those relays and brute forcing them out. Neighbors probably thought I was nuts.
NeverSatisfied
eBay Baller
Wichita, Kansas
Yeah I already had the 6-hi mod done but wanted the auto fogs. Didn't want to deal with all the splicing and found your way and couldn't be happier
Yuko04
"SquareBODluvr"
MN
Just to add a little insight.
If you flatten the end of the diodes with a hammer, they fit in the relay prong holes so much better and easier.
Dont go crazy when you are hammering the tips of the diodes. Just a couple of whacks to get it out of roundness and flat like a prong.
Took me 10 min and looks sweet. I just gotta get HID's for my high beams now!!
Chevyy4lyfe
i know its an old thread but just sayin i did this by switching the wires in the steering column around so i have the 4 high with my switch and when i pull back (like you usually would for 4 hi) i get the regular 2
SteveCZ28
Greene,Ia
i tried doing the 4 hi mod. bought 2 diodes, 1N4004 from radioshack. tried doing this mod, and it doesnt work. tried turning the diode both ways. gray bar towards hi relay, and towards low relay with no luck. tried both diodes, and got the same results. what am i doing wrong??
Drif10
Moscow
I love the pennytech mods, this a great one, really useful. Thank you to those folks that took the time to post pics and describe this easy mod.
Flomaster
This post really cleared things up for me. I want my fogs on with the lows, and the lows in with the highs.
Stupid simple right here. That first OP post work fuzzy photos really messed me up. I'm a visual person who likes to see things.
I also wouldn't mind the DRL, lows, and fogs on 24/7 and pulling back or switching forward on the high lever creates 8 lights all on at once.
Merch619
