Atomic
Hey guys, I have been making these for a while but wanted to see if there was any interest on this forum for this sort of thing. Its a bolt on kit that allows you to use aftermarket coilover shocks instead of the factory torsion bars on 4wd gmt800 trucks/suvs.
I did this on my truck (99 silverado) and have about 1000 miles on it and it works great. I have mine set up for drag racing so the CVs are perfectly level, but the same idea will work if you want to go lower or higher. You can get around a 4" drop with the factory spindle and LCA, or a 3-4" lift in front with the factory hardware. And the best part is you have dozens of spring rates and shocks to choose from so you can have your truck ride exactly how you want it. Weight savings is about 40lbs but that wasnt really the point of me making these.
I am at work so I cant post pictures, but they are fully welded 3/8" steel with 1/2" grade 8 hardware and powdercoated flat black. I sell the seperate lower bracket (which you need), and an upper bracket that reinforces the shock hoop (optional). Both together are $315 and either seperate is $180. The whole swap can be done for around $700-800 depending on what parts you use (brands of shocks/springs). I only sell the brackets.
Anyway, let me know if there is any interest and I will post up my full write up. I sell these on a couple other forums, mainly GMFS and performancetrucks.net.
I am new to this forum, but not to others, im a supermod on PT with close to 10k posts, and have almost 7k on FSC and about 1k on gmfs.
Thanks
EDIT:
Edit: I updated my PDFs to include details on the lifted-style upper mounts. This is the same document as before with some additions to include more information.
PDF Explaining the swap: http://www.mediafire.com/view/vkzapsyvtwu5rv9/coilovers_about_v12.pdf
PDF Explaining the installation process: http://www.mediafire.com/view/35n4kssw5cy4ddg/coilovers_install_v12.pdf
Edit1: I added the spreadsheet I made to help with picking out shocks and springs.
Thanks
EDIT:
