FINALLY! Retrofit TSX HID projectors into Depo headlights
WHITEOUT
Dont Hate-Appreciate
Phoenix
It has been a long time coming, but I finally got it done :rocking: I've had the TSX projectors for probably a year now. Just never got around to doing it. I know it's nothing new. But I did want to install them so I could potentially remove the projectors easily, and do it all without removing lens. I came up with a plan on how, that didn't exactly work out. Of course. But I was able to figure a way could still remove projectors fairly easy. So if ever wanted to change, fix, remove, do cutoff, washer, color ect...mods, will be able to, without cutting it all up.
Didn't plan on doing a full HOW-TO. But took some pics, and thought I would explain n show, how I did my HID retrofit.
Parts used:
Depo projector headlights, TSX HID projectors w/clear lenses, Matsushita ballasts & Osram OEM bulbs.
Retrofit install:
Removing Depo projectors is easy. Heat gun, few screws, pull apart. Love how easy it is on these lights.
I had to remove bezel from housing, cause it needed to be trimmed. Removing it sucked. I had too grind down an area inside housing. You can see the spot at bottom of inside opening. Then fenagled the bezel out of the opening..PITA!!!!!
The bezel had to be cut so TSX projector would not push it out towards lens. Hole size was perfect, just too deep. Pic of how much cutoff.
Cut bezel and TSX projector.
Now, I planned on fiberglassing a flange around entire opening, then bolt projector to that, make removable. But that ended up not working out. Which sucked, cause I spent a night making the fiberglass piece, move on. Getting the projector lined up was a process. Since opening where projector sits is flat, no worries there. And bezel can't move up or down, only left and right. Lining up projector to bezel up & down, then figure placement of projector from left & right. Then lined bezel up to projector lens left & right, had placement for both set. Secured the bezel to housing first, then I could easily know where to place projector. All fairly easy, just a lot of moving around, checking, double checking, triple checking placement, and look. Applying HID light to ensure proper alignement(straight cutoff) best as possible. The TSX projector is so nice for this retro. Size, shape ect.. Great fit.
Now that I had bezel secured to housing and lined up for projector. It was about how to secure front portion of projector, lens part, to the headlight housing. So I ended up using the original sealant/adhesive that Depo had used to secure there projector to housing. Stuff sticks very well, and since it can be heated up and removed. Was exactly what I was wanting use, making pojector removable. Heated up some of the adhesive on projector and housing, and lined it up to the bezel. Which was my guide for the placement, left/right, up/down, for projector. Just had to ensure the cutoff was flat/straight, tilt wise. Which was tough, since projector is two pieces, and front half only has lens, not cutoff. So had to eyeball it, and hope I got it straight. First try luckily! But again, nice thing about using that sealent/adhesive. Can be heated up, and re adjusted if need be.
The sealent/adhesive worked out great. Used some nuts n holts to secure rear half of projector to front. All holding pretty strong.
Installed bracket. Which went right on without having to modify or trim. There's a bracket that was for housing and original projector. Luckily it cleared new projector without needing to cut. May add brace. But feels very secure as is. We'll see how it handles.
Finished project. Retrofitted Depo headlights w/ TSX HID projectors.
All low beam. No highs. Dam bright
Still gotta adjust em. Nice crisp, flat cutoff.
Took about 4-5 hours. Good hour figuring out how I was gonna attach projectors to housing, since my original plan didn't work out. I still need to cover/seal around the projector to housing. But have an idea what to do and use so it will be sealed. Looks like nothing was changed, cosmetically. Simple and clean looking. Turned out great, and it all fit so well, and even cleared everything once installed in vehicle. So happy I finally did this, because they are BRIGHT! Wasn't as hard as I thought it was gonna be. Should have done long time ago, seeing how much brighter they are then before. Sorry for the long thread. But wanted to explain the process I did to retrofit TSX projectors into these Depo headlights. Without removing the front lens, and making projectors more easily removable. Maybe give others ideas on how they can retrofit some HID projectors into Depo housings, or others possibly.
Tahoewhat
Ballin' on a Budget
TX
Looks good Austin. Bet you can tell the difference big time between the two. I have 4 projectors on mine. Dont think much of it till i drive someone else's. lol..
(btw- still waiting on an address, ha ha)
WHITEOUT
WHITEOUT
Phoenix
Thanks guys! Ya, huge improvement in light output. And thought the Depo's did a good compared with other lights I've used with HIDs. Obviously true HID projectors are far superior, and now I getta benefit from them. And no longer getting my shadow in front of me when a car with OEM HID lights gets behind me. Ha
Did you have an HID kit on the depo lights before you did the retrofit? If so how was the light output? I keep reading depos work pretty well with them, but of course not as good as a retrofit.
Engine bay looks nice as well with the painted pieces. Did you completely paint the fuse box or just the cover?
Buck
FL
Nice job, thanks for documenting the process for us all to see.
Truck looks fantastic :cheers:
NathanJax
Vacation Nathan
Jax, Fl
Awesome!!!
kses123
kses123
Raleigh, NC
Looks really good! I hope you're going to seal those up from behind though...Lot of holes exposing the projector.
01Konvict
Boats n Hoes
Raleigh/SML
Gota love a good retro! Good work! My Morimoto Minis in Denali lights are awesome and make huge difference in light output.
WHITEOUT
WHITEOUT
Phoenix
Yes, had HID in the stock projectors. And they did actually work pretty good. But noticed when I removed them, the chrome layer inside bowl, had started to fade. HID bulbs must have gotten a little too hot.
Thanks, entire fuse box is painted. Along with a lot of other pieces in engine bay.
---------- Post added at 10:20 PM ---------- Previous post was at 10:20 PM ----------
Awesome!!!
Thanks!
---------- Post added at 10:27 PM ---------- Previous post was at 10:20 PM ----------
Thanks. Have temporarily sealed it. But have a more permanent, but still removable, solution. But living in Arizona, luckily we don't get too much rain.
---------- Post added at 10:43 PM ---------- Previous post was at 10:27 PM ----------
looks good bro, can i ship my headlights to you?????
Thanks Junior. Send em on out :Handshake:
I was really surprised how easy it was. That being said, wasn't a walk in the park. Had really planned it out and did mocking up before hand. Luckily had my old Depo headlight set laying around, and took one apart to see how it all was gonna fit and go together. So that made doing it so much easier, knowing exactly what I was in for, and what needed to be done. TSX projectors were such a near perfect match.
CAResearch
Yeah I am not up on headlight specs/terminology. I do want HIDs for 2004 Denali, is there a part list somewhere? The op install pics helps, still confused what parts to buy, though
WHITEOUT
WHITEOUT
Phoenix
Don't mean to Hijack, but what is a good HID for OEM Denali projectors?
Believe someone awhile back also used TSX projectors into Denali Depo projectors, and fit great. Any HID projectors could technically work, but may require more modification to housing and brackets. TSX have always been a very well known projector, with great light output, cutoff, color, modification ect... and great size to fit most housings easily. so retrofitters liked to use em. But S2K r awesome, and RX330 supposedly great too. But there so many projectora and also newer stuff out, different models, that should work very well.
---------- Post added at 11:32 PM ---------- Previous post was at 11:07 PM ----------
Assuming you are referring to HID retrofit, not just adding HID bulbs to halogen headlights.
Retrofit you need:
Set of headlight housings, HID projectors, HID ballasts, HID bulbs. Possibly bezels, if HID projector lenses are bigger/smaller then current bezels in housings(if projector lights). Wire harness/relays if want. If using OEM projectors with D2S bulbs, but afermarket ballasts, will need adapters.
You don't have use projector style headlights to begin with. Many retrofits are done to reflector housings. But main reason I originally chose Depo projectors, cause I knew they were removable, and size.
Then it's all about retrofitting them in.
My suggestions for doing a retrofit is, PLAN, PLAN, PLAN. The more you can visualize, measure, test and plan how it all will fit and work. The easier and less stressful it will be when you do it. And having an extra set of headlights to put in vehicle while your doing this, will ease and give you all the time you need. Not worrying it needs to be done, now.
BadDaddy2003
