NaomiSays
Hot Tamalé!
- Joined
- Aug 4, 2013
- Posts
- 24
- Reaction score
- 0
Not sure if I am ready to void the warranty and get it chipped to remove some of the TM.
Here is a stock table, the numbers are % of throttle allowed. You can see it is very restrictive down low.
First of all yes this is a stock table from your generation truck. The reason you can't see it is because you do not have a workshop version edition. And like you said your experience is very limited which is why you should trust me, the person who knows what she is talking about. If you want advice please don't knock down the correct answers. I went out of my way to open the file and find the one you want, so a thank you would be more appropriate.
I wasn't trying to be an ass, I was asking you to clarify what vehicle the data came from...and you come back with a rude and dismissive post essentially calling me a moron?
back on subject . Something definitely is not right here unless the ramp is really steep or you're pulling a 10k+ boat. I've had zero issues with mine.
No thanks. Wouldn't want to put you out....I went out of my way to open the file and find the one you want, so a thank you would be more appropriate.
Op did not say a model year so I grabbed a file from a 5.3 tahoe of this generation that shows typical throttle restrictions and sent it to Naomi to use. Even in cases where the restrictions in this table are less than this they can be found elsewhere in the program. I stand behind her original answer that there is a lot of power management in that area and a noticeable difference in performance comes from eliminating these interferences. I also stand behind her other comments as she was rudely addressed even after working to help answer someone. As far as answering a lot of threads that is her job and she does know much more more about these matters than most members. She is due respect and will continue to prove it, your judgement of her life style etc is not needed here.
We apologize for any miscommunication on our part.
