andrewlee
Gave a friend a ride to pick up a couch and truck overheated so I pull over to find heater valve has broke to peices and I had no coolant left. Lucky was 2 blocks from auto zone but the ****** there couldn't find the damn part I needed and I had to find him the part number.
note2
Monstar_est87
City of Angeles
Yup nasty lil buggers... They bcome brittle over time and just fall apart like that... :shrug:
Gzes
the drifting 2dr
Wichita tx
Yup my dads ranger did that aswell. Not hard to replace but they break from regular use
slipping
Rosamond, CA
note2
Been there. Spliced mine together with a cut up straw and some green masking tape. 3 miles out of a little town in middle of nowhere. Good job helping homie do his job.
Trippers99hoe
SW Oklahoma
Well last week I paid to have the window motor replaced,new door hinge pins and bushings and outer door handle replaced.Oil changed and grease job....Then loaded up and drove the old hoe on a 2000 mile vacation.
We caught an Aaron Lewis concert in St louis Mo on Sat. Then cruised to KC for a couple ballgames..Seen at least 10 Very nice OBS hoes on our roadtrip.Oh and averaged 15.8 mpg for the trip
billowred
Got new tires today!!
HERCULES TRAIL DIGGER MUD TERRAIN so far so good.
95BlackTahoe
Edinburg, PA
Took the time to put the Caddy fans in. They can cool a Northstar V-8 stuffed in sideways, they can cool the Tahoe...And does it ever.
I used two Haden temp controllers, and used 2 30 amp add-a-circuits. I looked up the wiring diagram for the year caddy they came out of, and it said that each fan has a 30 amp fuse. I did exactly that, and ran it for a few hours. Not a hot wire in the place. one fan fires at 200, the other will come on at 220. The second fan never turned on until i made it come on by tweaking the settings, then I turned it back. I need to figure out now how to hook fan to up to the A/C as well in addition to the temp controller.
I am very pleased with the outcome, and plan to do a write up. Mileage is unknown yet, but I do know drivability is much better, and it don't come out of OD on hills any longer...pulls like a champ! Well worth the effort!
Shawn
Monstar_est87
City of Angeles
Tap 1 of the fan trigger wires to the green wire on the accumulator or the condenser... Wen I tapped the accumulator the fan stayed running even wen the car was off...
And there is a write up...
Drewphil
