retorq
Kingman AZ
Got a pan leak on the tranny, gonna drain it, throw a new gasket in it and redo the cooling lines and aux cooler.
619NJ
Fixed my auto-dimming, temp and compass mirror. Still haven't gone after the DRL module yet.
andrewlee
I Waxed n shined tires
note2
noJeepshere
Bountyfull, Utahrd
Who just washed his truck wish concentrated dish soap? This guy :D
cent frum a smaert fone
It was all worth it though, the dish soap strips the old wax off, then a clay bar to really remove the gunk, then a liberal application of scratch remover, followed by two coats of wax, along with plastic cleaner/polish, and armor-all for the tires. She's shiny :D
_Dylan_
STAY FROSTY
shiny :)
bought some new jackstands today. Hopefully I will be putting on k3500 front calipers soon.
rolfsent
Cincinnati
New steering box, ball joints, pitman arm, idler arm and alignment. Also did the spark plugs and serpentine belt.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Same here, that or a wheel bearing. The 'Hoe serenaded me on my way to work this morning. Not a good singer...
Well my rear drums were long overdue for adjustment. tightened them up and got some pedel travel reduced but with in say 5 miles of driving they started to groan when the vehicle is becoming nearly stationary. every time when i switch gears directionally. sounds like a have u joints with no caps. this is just the drums tho. Hoping tho burn them out a bit to shut them up but right now i maybe drive 15-20 miles a week. if i ever start making any money again i got to get rid of them and switch over to rear discs. only one step in a process. i have come to the conclusion that my brakes are just not strong enough. if i can start making some money again. i will switch over to the rear discs with the better mc. change the front to dual piston calipers and finally rebuild the hydroboost and get it installed.
Drewphil
