Headers 5.3>6.0
Stein2088
Butler, PA
So i'm about set up for the engine swap. I've looked around for a thread and didnt find any threads out there with info on this. Does anyone recomend a aftermarket header to run on a 6.0 block but I need it to hook up to a 5.3 exhaust???
FreshLikeOprah
The 6.0 and 5.3 are the same platform and size externally. Only differenence is a 4.00 bore. Everything that bolts to a 5.3 will bolt to a 6.0.
Texas Speed makes a nice ss header with 1 3/4 primaries for about $370 plus the cost of a y pipe.
S
Stein2088
Butler, PA
Does Texas Speed have a website??? Also I was told that the only real difference is that a 6.0 has Dee shaped exhaust ports on the manifold and the collector is different (6.0 manifolds wont match up to the 5.3 collector/y-pipe) but they 5.3 manifold will mount to the 6.0 headers.
ezdaar
Chat Troll
Redneck central, Aka Houston
Are you serious!? here let me help you, the link he posted is the wrong one. this is it..
www.GOOGLETHATSHIT.com :mfr_closed1:
FreshLikeOprah
Nope, exhaust ports don't matter. They will work. Anything for a 4.8/5.3/6.0 will work. The 8.1 is the only non gen III engine. Do you plan on doing anything else down the road? Cam, etc. Texas Speed is a good company, and quality products.
livingez_123
Sandy, OR
there are a few good companies out there that make a good long tube header for our trucks. as said above the exhaust post won't make a difference. Do you plan on going to duals or just a 2 into 1 Y pipe. Pacesetter makes a nice unit but there are enough options out there and info for you to make a good decision. Also read the signature line of the members to see what everyone else is running. you can also PM them to get there opinion.
vtxtexan
