_Dylan_
STAY FROSTY
Successfully managed to install some tint on the front windows today. Pretty proud of myself for that. :lol:
97WhiteYukon
ac door? it is either mode, temperature or recirculation door motor?
Maybe a/c door isn't the right word, it's the actuator that goes behind the blower on the pass side. It opens the flap for outside air.
Another thing I did today was clean up the factory cig lighter well because my new stock lighter showed up today to replace the nasty used and rusted one that came with the truck. Then i had to replace the starter, it went out on me after I put everything back together and tried to start it.
noJeepshere
Bountyfull, Utahrd
Pulled a Ford out of a ditch
Goodinblack
I Like Tacos
Dirty South
Libtards.
Blocking the pipeline and blocking new drilling here in the US. Decreasing value of the dollar.
People thought gas was high under Bush too.
There is a greater rea$son.... just saying. Beyond party.
I am not a ******* by any means. :cool:
SunlitComet
OBS Jedi-Do Good
unknown at this time.
the availability and output of refineries available, seasons, supply & demand and additives package. any time a refineri shuts done output in the are is reduced and cost more to replenish it. refineries have to shut done everytime they do a seasonal change in fuel blends as well. the cost of doing business in a given are also effect prices.
---------- Post added at 10:53 AM ---------- Previous post was at 10:51 AM ----------
Libtards.
we produce more of our own crude oil then we have done just a few years ago.
_Dylan_
STAY FROSTY
le picture of the tint
Also got one wiper done. I was able to fit a 22" blade. Looks kinda hacked, that was just me fighting the damn wiper arm and the stupid spring on it.:emotions122: Getting some paint in a few days.
SunlitComet
OBS Jedi-Do Good
removed all obstruction to get valve covers off to put in new comp cams 1.52 roller tip rockers. new ones are in place and i am going back out now to lash them down. i want to finish that and do the dizzy before the end of the night.
slipping
Rosamond, CA
Tint looks good! Hard to do? I want to redo mine as soon as i get my ticket signed off. Gonna pick up some wipers tomorrow also and do the extend.
What's involved in replacing rockers? Simple swap or not? Have to be run to adjust them?
sent from my paranoid android
_Dylan_
STAY FROSTY
It came out good enough that I won't be ripping this off. Seemed pretty easy once I figured out the right way to do it. Going to put some 20% over the back windows soon.
The previous times I've tried it I was doing it completely wrong. I never cut it out first on the outside of the window and that's the trick. Previous times I just stuck it on and it came out like crap. :lol: I think I posted this before, but I did mine just like this:
http://www.youtube.com/watch?v=M7UOQq3h2s8
A tip on the wipers, if you can cut the flat wiper arm rod without taking the spring off, then do it. My dremel is broken and that spring was a pain in the ass to get back on. Not looking forward to the passenger wiper spring. :lol:
SunlitComet
OBS Jedi-Do Good
new 1.52 com camp rockers are in as well as the new msd dizzy. the cylinder heads new since about 15k miles still look very clean. for the rockers the difference before and after is about the same difference i got when the engine got the k&n fipk. since uprades dont add power cumulatively it is what i expected. after i get some mileage in the computer should relaern fuel system variances and i should see a tiny bit more. another $ 180 for horsies. next mod is getting the headers in. could not do this month but good chance in the first two weeks of march.
GMCYukonDriver
CA
Dropped the transmission pan on Saturday. Changed the filter and put new fluid back in. Man, it had been a little too long. The pan had some nasty gunk in it, but no metal shavings or anything. Fluid looked like motor oil.
Now it's shifting firm and tight. It had been slipping a bit between 2-3.
Also changed out the thermostat that was stuck wide open. This one lets the truck get up to temp much quicker. That was a pain, because the whipple is right above the t-stat housing, and I couldn't get the stud out. Took me hours to figure out how to get that out of there without taking the whole thing apart.
_Dylan_
STAY FROSTY
how many miles on the trans?
lets take a guess on mileage before the new fluid change blows up that trans too lol
this.
I'm a believer in either never changing the fluid or (if you buy a car new) changing the fluid regularly.
GMCYukonDriver
CA
I didn't flush it, just dropped the pan and drained what was in it.
Trans is original with 195k, and it shifts great now. Never had a problem with it not shifting into drive or reverse.
Still planning on having it rebuilt when it finally goes. Saving up my money for when it finally dies, but it's still going strong for now. I think part of it has to do with the trans cooler, that helps keep 'em alive.
SunlitComet
OBS Jedi-Do Good
if discolored or burnt smelling or severe service exist gm say you have to change it by just with a pan drop and filter. no flushing.
---------- Post added at 07:02 PM ---------- Previous post was at 06:40 PM ----------
second battery tray installed today.
Drewphil
