Sp1nn3y
North West Georgia
Fixed some of the fading paint on the hood.. i really need to spring for a good paint job already.. Did some cleanup work on the interior.. going to start replacing and recoloring the inside piece by piece i think.. need to start out with some nice LEDs :D
McFizzl
Broke as a Joke.
Fayetteville, AR
Programmed my keyless remote. Works great. Had to make a jumper to program instead of what the instructions say to do.
Gzes
the drifting 2dr
Wichita tx
Put my tail ligbt guards on, pulled the tire carrier, put my toolboxes in and have plenry of space behind them for my subs
Donnie Yukonie
Yates Caretaker
Tail light gaurds look good what brand are they? I went with westin
sent from my vortec powered droid 4 using tapatalk
_Dylan_
STAY FROSTY
I don't see why you would need them on these trucks. They don't break that easy compared to other vehicles.
The front lights/grille definitely needs something protecting it if you're romping around in the bush.
retorq
Kingman AZ
Took a pic as it rolled over to 280K ... rebuilt tranny x2, rebuilt top end, rebuilt rear end, not too shabby.
noJeepshere
Bountyfull, Utahrd
remember guards will only go the tailgate type rear body.
Good thing I have a tailgate ;)
That's what I figure, but even though I'm kinda more function over form person, I like a little style too.
carrolldad
Rear Diff
Changed the rear diff fluid. Also, changed the transfer case fluid. Then I realized I may have made a mistake and put autotrac II in the front differential. I am confused. Is there a transfer case and a front differential?:doh2:
97WhiteYukon
Changed out my ac door actuator from under the pass side ducting. Managed to do it without rolling the dash forward either :peace:! Sorry I'm a little excited about it. I was dreading rolling the dash forward again and causing more cracking, it was a tight squeeze and for some reason the screw there that there is no way I would be able to get out without taking the dash out was already missing, so I had to work out the other two in a long painstaking process. You know the kind that makes you smile like an idiot even before you finish putting the new one back in? Anyways another check off the list.
Drewphil
