i wanna slam my 03 all wd denali!! HOW???
goozdenali
Banned - Bad dealings with members
massachusetts
hey, im new to the site and already love it. i have an 03 yukon denali all wd. i wanna really lower it. i have a mcgaughy 2/3 lowering kit with keys. i havent installed it yet but i already know i wanna go lower. the 3/5 kit they have is only for 2wd. what can i do?
goozdenali
goozdenali
massachusetts
hey max i like your drop is it all wd if so wat did u do
---------- Post added at 06:46 AM ---------- Previous post was at 06:45 AM ----------
thanks blackdenali so wat did u end up with i know u had the same ?? i had
Modded
That Guy
Do a McGaughys 4/5 srop with spindles and keys cranked one inch up front while you rune a 5" coil out back with shock extenders since you most likely have Autoride.
You can get the whole kit listed above from Tim the McG vendor on here, you will look about how Max looks, though he has a bit lower than a 5/5 setup due to the keys being cranked more and other mods.
goozdenali
goozdenali
massachusetts
ya ima do the same, just a little concerned if excessive bouncing in the rear but if so bags should help. hopefully my kit will be in on friday, ill keep u posted
Max
Mile High
Denver
Should ride fine with helper bags. I wish mine were lower.
Max
Mile High
Denver
I figure if the front is an inch lower I'll have to bag the rear asap. 29" up front would tuck an inch of tire.
Jumpshot12
