Rims problems 305/40/R22 HELP !!!!!
felixgun
Lafayette, LA
You need to find the offset of your rims. Each rims offset is difference. Jewel above explained what an offset is. I too think it must be your offset because I have the same size tires and I have 0 rubbing.
CYKBC
305s are too wide unless you run wheels that poke out. Rear wheels will likely rub under compression with load and fronts may touch sway bar at full lock.
You'll be better served by going to a local tire chain store. Doing fitment stuff online is a challenging endeavor if you don't already have a basic grasp of wheel/tire fitment.
Gl
PUNSHR
I run the 305/40/22's on 22x9 Escalade replica's with a 2-4 drop. I have a slight rub in the back on the inner fender liners when i hit bigger bumps or my rear articulates on some small inclines but nothing major.
NYone
