Help/lowered to stock maybe lift
godoy
utah
Need help with removing my lowering kit(I payed mechanic to put it on the truck) , have the 3/5 custom kit from tony
I have my stock shocks, control arms and coil springs
And around how much would I expect to get from the kit??
Thanks
Alex33
Wish you were closer, I'd be happy to help you swap out your suspension. Best of luck with your sale bud.
godoy
godoy
utah
No not at the moment
Just gotta find some time to remove it I work a lot !!
Junior209
If u sell you're Kit I'll be interested in the rear springs were are you from
magicbus
Wichita Falls, TX
Too bad you aren't in Texas, I would swap with you. I posted a craigslist ad hoping someone would trade me a 3/5 for my factory setup. I ended up getting a reply (wasn't expecting it) and bought a DJM 3/5 with helper bags for extremely cheap.
NORCAL SS
SUV SUSPENSION GURU
make sure to get new balljoints and bushings on that kit. Also are the arms the old or new version?
magicbus
Wichita Falls, TX
I have new bushings and cam locks that I ordered for my 02 Silverado that had a DJM 4/6 and never installed them. Their site lists the same part number for both kits so I'm hoping they will work, but I haven't asked anyone in the know yet until now. I had already planned on new ball joints, no sense in not doing it since the whole thing will be disassembled. I believe the arms are the old style, I actually ended up knowing the guy that I am getting the kit from, he removed the kit 2 years ago. I haven't gotten too many specifics from him yet as far as how old the kit is. I figured upper and lower arms with helper bags, shocks, and rear hardware kit for $300 was a steal.
NORCAL SS
SUV SUSPENSION GURU
no prob id check it before if its the new version will work.
Rear kit rides bad i havent used the rear springs in years the tb new version spring i sell sits lower and rides better. You will see the rear will ride bad especially with the djm shocks/djm 5 inch springs
magicbus
Wichita Falls, TX
Right on, I'm already planning on the rear being temporary. I like cali lean so they will more than likely not be low enough for me anyway. I am contemplating running air in the back either with a standard bag or the trailblazer bags. I'm torn between air and the 6" springs you have advertised.
godoy
godoy
utah
So anybody want to help
I think I know how to change rear
Unbolt bottom if shock unbolt swaybar. Bolts and raise truck up and change springs right ? Oh and the trailing arm bracket right
And front I have no idea
Alex33
If you can do brakes, it's pretty straightforward. PM me and i'll give you a rundown.
godoy
godoy
utah
Ya I can
Thanks and ill pm you once I get some days off work
Do I really need stock trailing arm brackets ??
Alex33
Ya I can
You should have OE RTA brackets. You just got the 3/5.5 kit, right?
NORCAL SS
SUV SUSPENSION GURU
yes in rear you will need to ditch the trailing arm relocators
in rear you will need to put the stock endlinks backon
godoy
godoy
utah
And put back stock trailing arms??or just bolts right up
And Stock endlinks are necessary?
---------- Post added at 09:50 PM ---------- Previous post was at 09:48 PM ----------
Only reason I'm bringing it back to stock is because I might sell the truck (might)
But the lowering kit is nice and have no problems with it!!
Alex33
Just bolts right up. Stock endlinks will def help but you could get by without them.
johnsonwillie199
