BLK TAHOE
- Joined
- Jul 10, 2012
- Posts
- 9
- Reaction score
- 1
Good lookin Yukon man!
Thanks man! Post some pics of your Tahoe.
Here are some updated pictures showing off the debadged doors and tailgate. Plus I added a rear view camera mounted directly above the hitch receiver.
Knovict Your Youkon looks awesome! Do you have any videos of the exhaust? I would really like to get my tahoe lifted a little bit. Where did you take yours an offroad shop or just a regular shop?
Snow, What is your lift? Is it keys or a suspension lift?
Also with this mild of a lift there isn't any need for longer brake lines is there?
A few more pics and this time loaded with a friends boat. The rear squatted a little bit but not bad and towed great.
Thanks! I didn't have the autoride feature but it could be pretty simple to keep. You will need shock extenders for the rear and what size coil spacer then make your own activation rod. For example if you get 2" coil spacers then make your own 2" longer level switch rod which activates the compressor to make the ride level. Its pretty simple and I thought about adding helper bags to mine and a level switch then hook it up to my onboard air tank.
It's my understanding that the 5100's are made for something lifted slightly, up to 3" give or take. Thus not needing shock extenders. I'm getting these for my Yukon XL and raising it 3" in front and 1.5" in the rear with a leveling kit.When mounting the 5100 shock did you need to use shock extenders or do the 510 just mount right back to the oem location?
