_Dylan_
STAY FROSTY
The pressure level on a vortec is also much higher than a TBI. So not surprised you got a face full.
Picked these up last night. 255/70r18 bridgestone A/Ts. 5 low mile takeoffs from a new jeep wrangler. These are $198 new, I got all five for $325. :D
Gzes
the drifting 2dr
Wichita tx
Yea mines a tbi but still i let the pressure out and as said just a squirt into my milk jug canister
retorq
Kingman AZ
...judging from the alignment measurements my axle housing does not appear to be damaged...
What numbers are you reading that tell you that rear axle isn't bent?! Looks like it has an issue or two to me ...
---------- Post added at 12:17 PM ---------- Previous post was at 12:16 PM ----------
Got it all assembled ... now to get it in. \m/
SunlitComet
OBS Jedi-Do Good
unknown at this time.
i know that but to get those measurement to see condition of axle they set it up to display everything. at any rate those reading show right now nothing bad of the rear housing. those reading are nothing in terms of causing any issues. my used tires in the back i got in columbus, oh. are the issue. and most is gone after the re-balance. the wheels use adhesive weights so still a bit of vibes there. they will get chuck eventually for new tires.
---------- Post added at 11:31 PM ---------- Previous post was at 11:30 PM ----------
btw i have so far ever seen an alignment measure o a solid rear that was perfectly zeroed out.
knoslf
Thornton, CO
took a video showing the mirror I bought a few months ago
http://www.youtube.com/watch?v=b_tdob6FFEM
Still waiting on my damn DVR cam for my truck that I bought 3 weeks ago. I hope its just taking a long time rather than getting stolen from my doorstep again. :flame:
saw the video and it looks nice! Do you have pics of where you mounted your reverse cam? I put a 2 din in my 99 Yukon and also have a back up cam but its the kind that mounts onto the license plate and I am considering other options as that might look kinda bad mounted there...
---------- Post added at 06:57 PM ---------- Previous post was at 06:55 PM ----------
knoslf
Thornton, CO
New tail lights on now...
Installed the tail lights most think are ugly but I think they look okay for now lol...wish the 3rd brak light was inside the vehicle instead of the roof.
_Dylan_
STAY FROSTY
Finally did the 4 high mod. (the glare isn't nearly bad as it is in the pics, stupid POS camera on my phone)
I have the license plate one I also want to get rid it. I seems to get kicked a lot down there.
knoslf
Thornton, CO
lol, im thinking of using my dremel to cut the 2 long pcs off and mount just the lens somehow for a cleaner look. wish me luck lol.
_Dylan_
STAY FROSTY
one of the mods i have some parts for but not all. really want to upgrade my electrical distribution system first.
Well with all four on it's 180 watts or 15 amps which isn't that much. The alternator puts out way more than that at idle.
All you need is some wire, butt connectors, a relay, heat shrink, and a fuse. Took about 2 hours.
I do recommend an upgraded ground cable for the battery. I picked up and extra .5-1 volt just doing that. The factory cable is only like 6 or 8 gauge.
Gzes
the drifting 2dr
Wichita tx
Picked up a practicay mint white hood for my hoe and am gonna run a dual amp setup
---------- Post added at 11:21 PM ---------- Previous post was at 11:18 PM ----------
Hodmjstone
