07+ Spohn Complete Del-Sphere Package
NORCAL SS
SUV SUSPENSION GURU
I have been getting a lot of questions since I put up the post that im using the Del Sphere panhard bar from spohn and just wanted to get some more info out.
Spohn now offers a complete rear package now to replace all the rear bars in the truck.
Package can be ordered in below link in Red or Black from My store page and by ordering as a group saves $40 dollars over ordering part by part
http://www.tbssowners.com/store/index.php?act=viewProd&productId=170
NOTE: If install hardware is required I offer that also. Please email me at [email protected] or you can pm me here or call.
I've installed this bar package on a few trucks and the way the truck feels is much better. All the rubber bushings in rear are replaced and when mated with the DJM swaybar is a much needed improvement. Also I set the pinion angle at about -2 degrees which when you hit the gas swings to about 0 which for the modded guys gives better bite out the hole. Also since there is no more of the slop the power hits the tires harder.
Due to my truck having the upper autoride links YOU CANNOT use the spohn bars on the uppers but I will be using the rear lower adjustable del sphere bars on mine.
Heres a pic of the stock lowers compared to the new uppers
THE YETI
Director of Operations
South FL
when you say the ride is better, are you referring to a more luxurious ride or a race-inspired ride? I like the way our Burban rides lowered on the 24s, if there is a way to make it ride smoother, I'd be inclined to buy, but if this makes the ride firmer and sportier, I'd decline.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
gets ride of the sloppy feeling the stock bushings give. Doesnt make it much stiffer just a lot more control when your going off freeway off ramps and over potholes and bumps.
Nice!!! Very cool upgrade and worth thinking about when I go 2/4 in the future :)
NathanJax
Vacation Nathan
Jax, Fl
Do you have this for the NBS?
The pics he posted are on a NBS. You can tell by the door handles.
Tony, with these, I'm guessing you no longer need the rear trailing arm relocation brackets from the DJM kit?
SRQYukon
Sarasota, FL
I already have the Spohn panhard bar. Any advantage to the adjustable lower controls arms with a 3/3 drop (other than tightening things up)? Is the pinion angle off that much with a mild drop like this?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
ive been doing a lot of these kits recently and the rubber bushigns on these trucks are shot in many cases. It helps that plus recenters the rear tires in the wells
jeffyrc
Bow Tie For Life
SoCal
im really thinking about this mod to. i have an 05 tahoe with a 2/3 drop. is it even worth doing? will the kit you offer work? also is it ok just doing the panhard or the panhard with uppers and lowers? sorry for the questions.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
If your rear bushings are shot i would do it. If not i would invest in the DJM swaybars I sell that will help cornering nicely.
Alex33
I have the panhard and stock sways and it helped a lot. I imagine the DJM sways w/ the panhard would def increase stability.
Conedaddy
