Might need new front shocks...throw some affordable options at me for an '03 Denali..
DenaliAK
Colder than you
Alaska
Just like it says.
Might need new front shocks. I'd like to maintain the autoride functionality, but throw some ideas at me. Trying to save money but still get quality suspension.
OEM are too expensive. I am familiar with Arnott, so other ideas would be preferable....
Thanks
JochenWoern
Sacramento, CA
Just like it says.
Thanks
Belltech
CEN2MENTAL95
Banned
Expensive Long Island, NY
I am going through the same scenario right now although I plan to replace front and backs. I don't care if I retain my auto ride if the ride does NOT suffer...I drive through pothole filled streets...don't need it to handle like my legend, want it to ride like the luxury truck that it is
are belltechs stiff over not so nice streets?
and I'm not looking to drop it if I don't have to (I like being high up and I have to be able to tow)
GM-MAN
MA
I know Bilstiens have ones that fit and have a module that lets you bypass the A-R without setting codes, Arnott sells them too
I hear that Monroe, now makes electronic ones now. not sure if it is a bypass or full A-R
CEN2MENTAL95
Banned
two of my autoride shocks are orange and two are white so I will assume two were previously replaced. I think the orange ones are Monroe
I would like a smooth ride. The cheaper the better but I'm not willing to sacrifice ride quality to save money
ATL
from my understanding the belltechs ride smoother than the bilsteins. im about to eliminate my autoride and give them a shot
baldd86
I have a drop truck which has beltech and it.helped the ride real good on my sierra.
Sent from my SPH-D700 using Tapatalk
chip
Cincinnati
I just replaced my front shocks with a set of Monroe (for like $40) and I love them.
ATL
if you dont think belltechs will suit your needs, check into the bilsteins
Alex33
The bilsteins are pretty firm. I did the monroes in the rear to replace my OE autoride shocks and they were the same. I eliminated everything and went with the bilstein HDs all around and it's def firmer, so that may not be for you.
I would highly recommend the products Arnott carries or go with some Monroe OE replacements. If you choose to keep the autoride function, it will be pricier than if you delete it.
DenaliAK
DenaliAK
Colder than you
Alaska
Thanks everyone. I still haven't decided what route to take, but I appreciate the input.
WildBill
I thought auto ride was only out back???
anyway, I've had good luck with Bilstien 5100s from 4wheelparts.com. I think they were lik $100 each. Good on the street but wonderful on pot hole roads or washboard dirt roads.
I just cant reccomment the monroe stuff. it all seems to cheap...you get what you pay for.
CEN2MENTAL95
Banned
So what is up front? I thought all 4 corners were air shocks ??
91RS
GA
Autoride does more than one thing. It has variable dampening shocks at all 4 corners (they all have an electrical connection). Only in the rear the shocks also have airbags built in for auto leveling.
OldWYLawman
