You guys use high mileage engine oil?
YNOT
YNOT
I'm going to try a different engine oil for fun, but I'm not going to do any Royal Purple on the drivetrain, I'm sick of laying under that thing.
Robert.K
San Diego, Ca
x2 on the royal purple, that stuff is amazing. My only problem is that It burns away kinda quick, or i might have a very little leak. dont see one, but about every 3 months I find myself add oil to it. thinking about going with the 10w30 versus the 5w30 in it all ready.wonder if there is any benefits. Doing RP in the Trans this weekend, working up t the Differentials and transfer case and the cooling system. RP all the way!
rdtahoe
NJ
The lower weight won't have an influence on oil use (0, 5 or 10) , it would be the "top" weight, ie: 30 to 40 that would matter.
A lower number in the lower weight flows better at ambient and cold temp start up than the higher numbers, but I am sure you knew that.
If you do not want to go from a 30 to 40 top weight, you could just mix up a half and half of 30 and 40 and get a "35" weight. If I were to do that, I would use the same brand though.
scottd
