wideband and boost gauges?
AtomicHoe094
Atomichoe094
cleveland, OH
looking for some gauges for me truck to start getting this project whipple under way. Anyone have any good brand names to go off of/model numbers?
On a wideband, whats a steady number to stay around? Ive never seen one in action so idk what to anticipate on this thing. Are the numbered gauges better or the colored coded ones like red and green lights???? thanks!
JennaBear
Resident Ninja
San Diego, CA
Didn't you already ask this question? Or was that someone else?
I have a PLX SM-AFR and an Aeroforce Interceptor. I will also plug in the EFILive V2 from time to time.
BOSS
The People's A D M I N
Dallas
I was reading on the Aeroforce Interceptor and I saw it listed HP as something it's capable of monitoring. HP!? huh? LOL
Transmission Temperature
Idle air Control
Counts Throttle Position Percentage
Throttle Position Voltage
Engine Load Oil pressure (some 8 cylinder engines)
Fuel economy (MPG)
Horspepower
http://marylandspeed.com/aeroforce-...-gauge-gm-obdii-vehicles-af1-obdii-p-404.html
B
95TwinTT
Minnesota
I have tried several different wide band's and settled on the Innovate XD16.
When you start using forced induction, it is no time to cut corners on the AFR gauge.
http://www.innovatemotorsports.com/products/xd16.php
Here is the link, check it out. The xd 16 has one great feature in that it can calibrate itself. I have two of them, one on each side. I also use it to control the ECM for closed loop.
The magic number for gas is 14.7 : 1.
BTW nice find on the blower....... :)
JennaBear
Resident Ninja
San Diego, CA
So you are using the LC1 then since the XD16 is just a gauge?? I assume that is what is calibrating itself rather than the gauge? I believe the PLX does the same. Justin has the LC1 as well, and likes it.
95TwinTT
Minnesota
It is true that the LC1 is part of the deal, but the gauge does have a ton of features in itself. like programming what color each LED will be around the dial. I also like having the actual number displayed all the time.
It LC1 is the in line package that interprets the signal from the 02 sensor. The other thing I like about the system is the 02 sensors are a VW stock item.
The LC1 has several different outputs. Analog as well as digital. In my case, I use one of the extra analog outputs to run the ECM with the wideband.
I have found several Dyno shops use the Innovate products for tail pipe sniffing. They seem to be very accurate. :)
JennaBear
Resident Ninja
San Diego, CA
Yep, Innovate definitely makes good products, it is what we are running in the SSS with the DB gauge. I am running the PLX DM-100 which sounds like is pretty much the gauge you are describing, I can access a decent amount of information with it, especially alongside the Interceptor. I am pretty sure that is what we will be running in the TBSS once the TVS goes on, we were pleasantly surprised with the amount of settings.
A
AtomicHoe094
Atomichoe094
cleveland, OH
Thanks, she was a pretty penny, but itll be worth it i hope : / I really never expected these widebands to be so damn much! lol i was thinking 100 or soo.. nope! ooh well.
well i had a poll up a while ago just asking what gauges were important to you, now i need brands and stuff like that.. sorry for the double..
---------- Post added at 01:31 AM ---------- Previous post was at 01:29 AM ----------
Anyone hear of Faze/sunpro gauges? Im not trying to go cheap, but on a couple gauges i love the color.. thats one thing that has to be with the gauges, same color across the dash..
dizhai
