*PICS* Installing 3/5 Drop on Denali
BlizzardX23
Sacramento, California
Welcome to the Autocraft Center!
Everyone was giving me shit cuz I lowered my front end... so until I get my suspension kit, I put the truck on the lift, got under and cranked the torsions the opposite way...now the front sits higher then the back...it sits about the same as the pics of it lifted lol...
it rides like ******* SHIIIIIIIIIIIIIIIIIIIIIIIIIIT...HORRIBLE handling, it shakes and jolts and jobs and barks and everything else with the T-Bars cranked..its slower too...I cant TAKE OFF anymore..probably because the AWD system isnt liking the front wheels being so ****** up and jumping up when I hit the gas lol...
Install pics come hopefully 2moro..if my kit gets in!!
BlizzardX23
BlizzardX23
OK...Im tracking my kit...its finally here in Lawton..so I'll pick it up this morning..and install it this evening...or at least the back...the place is open from 1PM - 9PM ...I wont get there till about 3...so that leaves me with roughly 5 1/2 hours to get hot on it...More pics to come!
NathanJax
Vacation Nathan
Jax, Fl
which 3/5 kit did you go with?
55belairtim
hes got the 3/5 mcgaughys kit
spindles keys for the front
coils sway bar end links and trailing arm relocators.
BlizzardX23
BlizzardX23
4got shocks too! ;)
Thanks again Tim, I appreciate everything!
I installed the rear kit today...like...3 or 4 hours... :( but its my first time...if I was to do another rear kit for a yukon, It'd be faster!
Also, a guy that worked there helped A LOT...thanks to him!
buuut...time was running short so I didnt bother with the front yet...I'll do it maybe 2moro?
anyways, the back sat down nice...still looking for lower though..hmmm...
I did NOT remove the D-bushings and slide them inward two inches and drill a second hole like it said to on the instructions...is that a big problem? Also, I didnt put the spacer sleeve in for the passenger side end link for the sway bar..it was angled...but didnt seem like it would cause an issue..any advice?
---------- Post added at 07:43 PM ---------- Previous post was at 07:38 PM ----------
also....yea yea yea...Ill post pics...but after I got finished, I went to a buddies house and we watched a really scary movie... =( then his garage door going to the house flew open cuz of the wind (all the lights were out also) He and his wife were on one couch, and my and his little girl were on the other...she was hiding under the blankets the whole time...
plus, its storming outside with a lot of lightning...so yea...pics will come 2moro though!
NathanJax
Vacation Nathan
Jax, Fl
Can't wait to see pics... I'm talking to Tim (55belairtim) in PMs about getting this kit the my Escalade...
Grocery Getter
A guy with a truck.
Phoenix, Az
Take out the spring isolators-plastic discs in the spring seats(1/2-3/4 more drop), you need to relocate the swaybar bracket so ig clears the panhard on the passengers side. While u hAve it up there cut ur bumpstop brackets off, you can use a swazall.
Grocery Getter
A guy with a truck.
Phoenix, Az
whats the panhard? and your talking about the two D-Bushings? one on each side? that hold the Sway Bar to the axle?
Right, the sway bar brackets on the axle. The panhard is just to the left of the swaybar on the passengers side:
The sway bar needs to clear this is order for things to work right, if it doesn't it will dig into your panhard or bend the sway bar. It need to clear like this so when the back end goes down the swway bar does not hit the panhard:This is looking up at where the panhard and swaybar meet
These were taken before I relocated my bracket, I had pulled the swaybar over as much as I could without relocating and the driver's side bracket was in the curve of the swaybar. Now that I relocated the bracket and was able to move the swaybar over properly I have much more clearance.
FYI: Your end links should all bolt on the passenger's side in order to move the sway bar to the passenger's side enough to clear the panhard.
BlizzardX23
BlizzardX23
This thing handles sweet! I like it...it does bounce though in the back now...like a cheaply lowered civic..but only on bumps and dips...but cornering is very nice...still needs to go lower though... the isolators aka rubber pads on top and bottom of spring arent that thick anyways so it wont make much of a difference...I still need to install the 2 inch drop spindles and keys...everything up front is stock, I just undid the torsion bars all the way...
hmmm...how to get the back 2 more inches? (without a body drop...thats extremely expensive)
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
i didn't read back thru the entire thread again and can't remember...so i'll just ask ya...
did you install drop shocks and do the bumpstop mod yet? that will get you a tad bit lower.
BlizzardX23
BlizzardX23
I got new drop shocks...I didnt cut the bump stop though...but, the bump stop will just make it bottom out earlier...it wouldnt make it lower...right?
briannorris
