L8RH8R
Rebuilt my front suspension to include prothane bushings and got an alignment. What a difference they had made.
Sp1nn3y
North West Georgia
Detailed the inside.. Fixed my back seat problem.. While i was about to WD-40 the back doors, my finger got caught and i broke my finger nail in half.. i ended up bandaging and i cleaned for 2 more hours.. Good day..
vtx1800sba
Michigan
Did my sway bar links this past week after discovering the passenger side was broke off. This is the third or forth GM SUV I've had to do this to.
96ProCompTahoe
IN
replaced the idler pulley hoping it would end the new squeak. (pulley had a little play in it) but of course its still there. PS pump, AC, Alt, and tensioner all seem fine. looks like it might be water pump time...again... or fan clutch (both replaced along with the belt since i've owned the truck)
992door
Greenville, NC
Replace the hinge pins on the drivers side door and the hinge pin with the roller. Washed and waxed it also
AtomicHoe094
Atomichoe094
cleveland, OH
Bought some more fuel line fittings and a few more parts to finish the whipple build.. been soooo busy with other shit and this whole gun/ccw thing i havnt had time to do anything.. heres a teaser i took today
oh and a shot of my shooting for the fun of it :D .357revolver
capt68
Sent the Hoe to the body shop
I took my wife's Black Hoe to the paint and body on Friday. It'll come home Victory Red.
the big blue bus
richmond, va
swaped my cluser to 5 leds and put blue in doors and cool white in the map lights. also wired the tow mirrior signals in and changed the bulb in 4wd to a blue as well and cool white in the glove box
strad
Las Vegas
Took the grille off and changed out the parking lights and the headlamp units with a set I got from 1aauto. The front looks like a new truck now, and I can see properly at night again. The latter is the reason I did the job in the first place, but having it look nice is definitely a fringe benefit.
And yes, I did try the polish route before going for new, but those old units were just too hammered by sun and rocks to respond at all.
vtx1800sba
Michigan
Did a brake job on rear axle. All original inside from 1996 right down to the nails. Shoes were polished and not much wear in the drums. Both wheel cylinders were leaking a bit. Replaced shoes, springs and both wheel cylinders. Cleaned all up. Bled the lines, good to go.
96ProCompTahoe
IN
looked at it in the driveway pissed that i haven't had the time/money to do/fix some things on it. Also wished it would fit in the garage :(
JcKinney
Albion, Michigan
Replaced the master cylinder and brake booster.... Two footed standing on the pedal to attempt to stop was just plain nuts.
Skeletoy
Arizona
Sprayed some more PB on my stupid A/C compressor clutch to stop it from squeeking. (It's 2 months old and I have to do this once a week.) Don't even want to mess with it since I spend over 500 bucks on the A/C this summer.
Tom danger Collins
I ordered the same thing. Glad to hear it looks good. Mine should show up any day now. Gonna have to paint the brush guard to make it looks all shiny and new. As far as what I did today, I replaced an AC vent on the passenger side and put in a new power window switch.
Sp1nn3y
North West Georgia
Agreed on this one, instead of spending that invisible money to make updates on my truck, i cleaned it.. seemed like the only thing i can do for now.
About to order some new headlights and get her an alignment/new tire.. 50 bucks for both axles seems pretty cheap to me..
Merch619
