Getting so sick of a bad ride in the tahoe
Nickleahy23
Portage/Menomonie, WI
I just cant take how crappy the truck rides lately..
My set up is stock shocks in front (they need to be replaced), keys in front , 5" coils in rear with helper bags, shock extensions and new shocks in rear...also have the free travel mod done..
i know with the 24s its going to ride a little rougher, but its horroble..my buddies busted cavilier rides better then my truck..
Would some spindles in front and crank it back up to get off bumpstops help out a little? in the spring i plan to replace tie rods, steering arms, maybe balljoints, sway bar bushings front and rear etc and see how that helps, along with shocks...but if that doesnt help im thinking of going back to stock..it just sucks lol
Cartwright
Going back up off the bump stops will help the ride. Just lift that thing. Stock is no fun :(
titanium02
w7's or bust.
Norfolk, VA / ATL
my yukon rides like crap too.. It was okay when I first dropped it but now it's so loose..
Every bump I hit I hear this clanking in the back. I have no clue what it is.. everything seems tight but who knows. The roads here are horrible and traffic usually flows at 60-70 so when I hit bumps it's like a roller coaster. Scary and hard to drive. :(
Looks good tho :waytogo:
N
Nickleahy23
ya ill be back on stocks here soon for the winter, so i might by happy for a bit..but in the spring ill do everything i said and if the ride gets no better ill be figureing something out..id love to go down to 20s or 22s for performance, but one of my rims is ****** so they aint worth anything
MeanGreen03
TX
If you want to stay with rear coil springs try out the DJM trailblazer 4" drop springs. Yesterday was the first time I really got to ride around in my Tahoe since I put them in. They are really soft and ride nice....practically stock. It didn't lower it as much as I was told but I couldn't take the ride of the other springs I had. I have the front DJM A-arms in the front. I haven't rode in any that have been lowered by torsion keys only so I don't know what kind of ride that is like.
Max
Mile High
Denver
Bilsteins and bumpstops homie...that 35 series sidewall isn't helping either.
N
Nickleahy23
you think bumpstops would help? im still prolly 4" from frame in the rear...i dont bottom out at all..
i think once i replace the front end parts, get some spindles and get off the front bumpstops ill be a little happier...shit was worn out when we dropped it 15k miles ago lol
NORCAL SS
SUV SUSPENSION GURU
i posted a tahoe up of a customer that was in his 50s. on 305 35 24 and 3/5.5 custom drop with djm shocks it rides pefect. Many other people have been going to the tb rear setup I sell and ride is a lot better than ANY 5 inch tahoe spring out there.
Trust me on this change to the rear set up i sell and your ride will be much better but you will need to cut off the bumpstop brackets for sure.
with my set up aka djm 3/5.5 and djm shocks all around truck will sit 1/2 inch at most higher in rear then front and ride is the best out there thats for sure.
wetvette92
Oklahoma City
I feel you pain, I have the 295/35-24's also and the ride sucks. I need to change shocks to see what that does, but I think it mostly has to do with the low pro tire/wheel setup.
Max
Mile High
Denver
He did the free travel mod, just needs better shocks front and back with some z71 front bumpstops.
NORCAL SS
SUV SUSPENSION GURU
nope its the kit. i put up pics of the customers truck on 305 35 24 with my 3/5.5 kit and he took his old set up off ie spindles/drop keys and the other rear 5 inch kit and put my set up on with shocks and rides perfect. much better htan old set up.
brndns_hoe
Plano, TX
what bilstein HD part number shocks are needed (front and back) for our lowered Yukons?
F4-BE5-E672-H0 (fronts)
F4-BE5-E380-H0 (rears)
this is what Max recommended to me, and I got, and am very satisfied. the rears are for our trucks....the fronts are for the Hummer H3, but work great...same dimensions as those for our trucks, but with an integrated bumpstop
N
Nickleahy23
What exactly does the setup consist of in the front? I cant go any lower in the rear..when im slammed in the rear(5 people in the truck, tucking tire), my tires rub the upper link bar mount on the frame..not good..i need to move the axle back about an inch to fix this problem...
with the helper bags in the springs, and new shocks on the back, the rear doesnt ride that bad...im hoping its more my worn out front end parts that are hurting it..ill start there(since it needs to be done anyway) and then see how it rides..
NORCAL SS
SUV SUSPENSION GURU
what does your truck sit at now from ground to fendelrip all around?
the rear djm springs i have spacers to sit it the same your at now but ride will be much better.
in front djm 3 inch a arms with djm shocks is what ir un for a 3 inch drop. Ride is great.
N
Nickleahy23
i believe im sitting at about 33.5 with the 32.5:" tires...im pretty much dead level right now...10 psi in the bags, new shocks in rear..front is just keys and stock everythign else, 170k....it all needs replacing..
do the 3" arms get you off the bumpstops in front? send me a PM on what you can do for a price for the TB springs and arms..only thing is im gonna have to buy new bags for the TB springs right?
also kinda thinking of getting rid of the 4s and going for some 22" TBSS replicas, grey with 275/45/22 Nitto 420s..let me know a price on that set up as well :secret:
NORCAL SS
SUV SUSPENSION GURU
the tb springs are wider so yes. But before you do pop yours in just to test out.
didnt get the pm on the springs or the arms shoot me one and we can go from there.
bub
jersey
did you ever figure out what was making your ride suffer?
N
Nickleahy23
not really sure...im back on stocks for the winter so that helped the ride a bit lol...in the spring im either gonna go with some drop spindles or drop arms, as well as trailing arm relocation kit and new shocks in front and go from there
Escalade2007
