How to do the 4 or 6 high mod on an 03-06 full size truck for $3.00
Narco
Atlanta
im putting the ss bumper on so ill be losing my fogs. so if i understand this right, i would only need to do the 4 high mod correct? the 6 would be a waste. no?
DenaliAK
Colder than you
Alaska
Correct. 4-high will be all you need to do.
PUNKYOU007
Hopewell VA
Any chance i can get a pic of said yellow wire to ground
---------- Post added at 12:20 AM ---------- Previous post was Yesterday at 11:51 PM ----------
Nevermind, I see now.
man your such a NOOB
hassoun
Germantown, MD
so i did the 4 mod on my 01 denali by grounding the yellow wire on the low beams. any suggestions on how to get the 6 mod done on my denali ? should i ground the fogs too ? or maybe wire them up to parking lights ? if so can anyone walk me through instructions ? thanks!
highrollin113
Undercover
Edmonton, Alberta, Canada
does anyone have two extra laying around and want to do me a solid and mail me two i cant seem to order to canada from the radioshack page and "the source" our old radio shack does not have the 3amp and want 4.99 for one anyway compared to 1.49 for two
Abn Panzer
Silly question... But Not knowing makes me nervous.
Would there be any problems if I shaved/sanded the ends of the diode's 'wires' to be thinner? I've seen where people said to jam them in, and someone flattened theirs with a hammer... what about sanding them narrower? Is there any issue that arrises with being thinner at the ends? or shaving off the outer coating of the wire exposing the copper core?
May be an obvious answer to some... just not me.
blackbeast03
NC
I just did mine, took all of 5 minutes. radio shack was out of the 3amp ones though, so i used a 200v 1amp, hopefully it lasts!
Physh1
Just did the 6 high mod today but I did do it a little different. Honestly, I didn't want to force 2 solid diode ends in with the relay pin.
I soldered jumpers to the relay pins and the relays still pop in all the way. I also used In-Sure 3-port push-in wire connectors so everything can be changed quickly. If a relay goes out it can come apart and the only thing extra to do is solder a jumper wire on the new relay.
I took a few pics. Since this is a little more exposed I also used heat shrink to cover the exposed diode leads. I got the diodes from Radio Shack...only thing with mine was the leads off the diode were waaaay shorter...another reason I went with jumper wires off the relays first.
Cameron
Physh1
On the High and Low relay jump pin 86
On the fog relay jump pin 85
chip
Cincinnati
I figured out the full time fog mod too, in case anybody wants to know.
adzam
New Jersey
So I just did the 4 high mod. Worked great. I then continued to the 6 high mod and my fogs were coming on with the highs no matter if the switch was on or not. I did not like this because one of my fogs is currently not working right so I haven't been using them. So I reverted back to the 4 high mod and my highs weren't working at all! I than removed the diode, tested and everything worked fine stock. Went back to the 4 high and it worked fine again!
Anyway, I am wondering if I did something wrong with the fogs. From my understanding they should stay on with the highs if they were already on but not come on with the highs if they were off.
I have an 03 Denali...
---------- Post added at 12:53 PM ---------- Previous post was at 12:22 PM ----------
I'm a little confused now... The OP said to jump 85 on the high and low relay
Physh1
I don't believe I am mistaken.
I just went out and looked at all my jumpers. From the drive side fender view of my fuse box all my relays are upsidedown. Meaning the "Orion" is upsidedown & on the lower RHS. This is exactly how things were before I did the mod & exactly how it was replaced when I was done. Every relay in my fuse box is oriented this way.
I have the wires on the lower RHS on HIGH & LOW socket pins in the box EXACTLY as the picture shows. The FOG uses the upper LHS socket pin.
As my relays are oriented all upsidedown by my pov the HIGH and LOW relay jump pin 86
& the fog relay jump pin 85.
In the pictures on page 1, the LOW relay is actually right side up and the others are upsidedown. Given the position of the LOW relay in the pic on page 1 the pin on the lower RHS would match pin 85 not 86. 86 is on the upper LHS.
I don't know if this matters but my high 6 works just fine. I wired mine based on where he said the wires went on the fuse box (lower RHS on the LOW & HIGH & the upper LEFT on the FOG).
Cameron
Phlipnstik
