j91z28d1
I need to increase my knowledge about what one can do with HP Tuners, because I had no idea this was a function. I've only used mine for disabling the AFM and some mild tuning. Thanks!
it depends on the vehicle and what's defined for you. but you can turn off most of the diagnostic tests the ecm runs.. it's good for engine swaps and stuff where you're in a 60s car with a manaul tranny and no cats needed. it's technically illegal to do, but they get around defeating emissions stuff by making you take a online test these days to access that section, and you have to know what you're doing on your own. all the info on their message board is there from years ago, but if someone asks a question and it brings it to the top they wipe all the how to's out. so it's slowly being lost
back in the day they just had a check box to click when yoh removed cats, it just automatically passed all the i/m test instantly but that option is removed, now you gotta dig thru each fault code relates to rear o2 sensors, and set to not report error and not set mil light. there's like 10 different tests for those alone. I still have the very old first version dongle and try to never update the software to avoid them removing functions like that. but they have me, as the first dongle still works, but they no longer allow you to buy credits for it. I think I have 2 left. when those are used up, if I need to unlock another car. I'll have to upgrade.
Scrappycrow
Air Force
Alpharetta, Georgia
Thanks for explaining all that. It's definitely a reaction to various tuners being taken to court by the gubment. I understand why they've done it, but I don't like it.
As for disabling stuff during drivetrain swaps, that's going to depend on the state. In Georgia, for example, large swathes of the state don't have emissions testing, and for those that do, it's a rolling 25-year cutoff.
JoeBlobs
Senior Member
NJ
Been doing a lot of work to the 'ol rig. Pretty much full front end rebuild after I find out my tie rods were smoked. Cleaned some rust spots and put some lipstick on her. I may or may not have decided to lower it as well. :Big Laugh: Oil pressure sensor and master cylinder with a brake bleed this week, then off to the alignment shop.
If anyone wants to pick up the old arms let me know, they're yours.
PG01
Up here to the right
Been doing a lot of work to the 'ol rig. Pretty much full front end rebuild after I find out my tie rods were smoked. Cleaned some rust spots and put some lipstick on her. I may or may not have decided to lower it as well. :Big Laugh: Oil pressure sensor and master cylinder with a brake bleed this week, then off to the alignment shop.View attachment 490647View attachment 490648View attachment 490649
Looks clean…. Unlike mine :(
PG01
Thank you sir! Nothing short of a miracle for being a NJ truck. My GMT800 on the other hand....
Mine was a garage queen for the first 6 years of her life… then she was banished to the driveway when i got the ‘19 yuk and it all went downhill from there…stupid NY and their crappy salty roads….;)
Scrappycrow
Air Force
Alpharetta, Georgia
I'd been noticing a teensy bit of moisture buildup in the right taillight, then we had some heavy rain and the teensy bit became a significant amount. I pulled the taillight and set it hole-side-down on the HVAC exterior unit and it was completely dried out in about 20 minutes. It turns out that the "breather" membrane at the top of the upper reflector had come loose and was letting water in, which eroded the silvering below it, as well as at the corners on the bottom where water pooled. I tried to clean off the staining where the water had been resting, to no avail. Then I fabricated a "breather" using a spray can tube and metal foil tape (let's hope water doesn't get in uphill via capillary action). It looks fine from 12' away, but I know it's "disfigured."
(yeah, there's a weird color shift on the one picture, but it wasn't worth it to get out my DSLR to get the colors right)
PXL_20260802_212530231.jpg PXL_20260802_212034118.jpg PXL_20260802_215948329.jpg
Speaking of water inclusion issues, I experienced one yesterday.
I had the front of the truck jacked up about 6-7 inches in my garage last week to fit my creeper and fat belly under the truck, when I was repairing electrical grounds. While the truck was lifted, I noticed a trickle of water exiting the underside of my second row passenger door, and I decided to blow out the door drains after I completed my electrical ground repairs.
When I removed the truck from the garage, I saw a water wet spot on the concrete garage floor that was 8 feet in diameter. That was a lot more water than I had expected to see, just from that trickle.
So, yesterday, I fired up my compressor, put the air gun attachment on, and I blasted the drain holes on that door. When I blasted the first drain hole, I heard a loud water bubbling/splashing sound, similar to waves crashing on a beach. And, then the water came pouring out. And out. And out. And out.
Without any exaggeration, somewhere between a quart and half gallon of water came out of those drain holes (in addition to what came out on my garage floor). 5 minutes later, water was still dribbling out of the drain holes.
I'm adding 'blow out the door drain holes' task to my periodic truck maintenance program.
PG01
Both sides…a few years ago exactly as you described joe.. like at the beach…lol
mikez71
When I got my tahoe a few years back, so much water got in the doors you could hear it sloshing when driving.
After cleaning the tiny holes out several times, and even prying the holes open a tiny bit, they still didn't flow worth a damn.
Finally I removed the little oval plug under the door weatherstrip.
JoeBlobs
Senior Member
NJ
Great reminder to clean these out. I dealt with this on a BMW, I've never seen so much water pour out of a vehicle.
In other news, I found out how annoying the upper rear shock bolts are to get to. Especially the passenger side.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
JoeBlobs
Senior Member
NJ
Thats a good little fix there. I saw someone bend a wrench on a 90* as well. Now to find one to sacrifice....
varminpoolteam
