Pwtr02ss home build
pwtr02ss
pwtr02ss
Tennessee
Here are the plans with grades added. This, of course, will be field adjusted. Gotta work with what land you have, and we bought some hilly, sloped land.
The good part is, if we add a pool in the future, it's just a retaining wall away. No digging required :driver:
Tonyv__
Bucks county PA
One of my estimators/project managers was showing me all the stuff he was doing to his house with Ai and asked if I had a plan sheet he could mess around with.
It's not perfect but it's close enough to have an idea. He used chat gtp or gpt, whatever it's called.
I thought you goobers were some kind of tech wizards when you were sharing cars in the yard and what not...that technology is simply amazing. Took him like 20 minutes to do this. I had no idea it was that easy.
Ai is insane. My realtor did this with my garage for our listing. 1st pic is the status of the garage during pics (chaos). 2 nd pic is ai generated but so accurate.
Edit. The concrete is not nearly that clean
pwtr02ss
pwtr02ss
Tennessee
randeez
south florida
Tonyv__
Bucks county PA
i guess i missed this but im picturing someone AI'd up mowing the law and trimming some bushes and sent them to tony??
Exactly that. At quick glance I was happy to see it done. But if you really sit down and compare side by side, it was a bad AI rendering. I’ll have to find the pics.
I was sitting in front of the campfire boozn though lol
THE YETI
Director of Operations
South FL
What’s your total under roof sqft? Maybe I asked before.
We’ve trimmed ours way down in an effort to start building sooner.
THE YETI
South FL
pwtr02ss
pwtr02ss
Tennessee
They started laying block yesterday. I got some videos from my builder, but only these few pictures.
The mortar joints are clean in the video and they were at least 9 courses on this back corner.
So, I decided to raise the control point at the front of the garage. This added 2 courses of block to whole foundation. The back will be 17 courses high, or 12' tall now. All of the 12" block on the bottom will be covered with backfill. In some areas, it'll be more, but I'm running brick to at least that point, so if some brick are buried, so be it.
I went this route for two reasons. It'll bring the front elevation higher than the cut, so I'll be able to back fill and get positive flow away from the house. It'll also allow the garage and driveway to be roughly the same grade as the big pad, instead of turning slightly downhill. The more we looked, the more I feared that we wouldn't be able to cut enough to get the water going away. Another reason, I have a mountain of topsoil that needs to go somewhere. I can use it in all landscape/grass areas. I'll have to import more compactable fill, but long term, I think it's for the best. For good measure, I'm also doing under drains on the inside of the foundation at all low point walls. That will be backfilled with stone, equal height with the fill on the outside. There will also be foundation drains on the inside, that tie into the roof drains.
Hopefully all of that makes sense
BadDaddy2003
