- Joined
- Aug 2, 2018
- Posts
- 10,540
- Reaction score
- 15,298
IMO, anything below 20 psi at hot idle is too low. I concur with the folks above to file a claim with Jasper now and follow their instructions.
Based on Jasper’s website, new oil pan comes with the long block. I know the oil pressure sensor is reused, but I replaced that with a GM sensor roughly 1 year/15k miles ago.some parts are re-used on a long block, I am not sure if the oil pump is one of them, or not the oil pan is for sure and I believe the oil pressure sensor is another and water pump and intake and the rest of the bolt on's, spark plugs should be new.
10 psi is the trigger for low oil pressure, technically 12 I would say is questionable, normally 14 is what you might see at hot idle.
at the very least when that 500 miles rolls around I would get a sample and send it out to blackstone labs or who ever you prefer.
Cold idle was nearly 55psi today. Historically I change my oil every 5k on all my cars and run a blackstone every 20-25k or so.cold idle mines goes a little bit over 40...hot idle I would say in the 30s..
I have noticed the longer I go without changing the oil the lower the oil pressure gets as I drive. But soon as I change the oil and filter the oil pressure gets better... I usually go by the oil percentage to change my oil but others change every 3k
Thats a really big difference to 10 psi hot...Cold idle was nearly 55psi today. Historically I change my oil every 5k on all my cars and run a blackstone every 20-25k or so.
No it wouldn't at all. Just gives a bit more filter area and oil capacityFilter used was a Napa proformer equivalent of a PF63. Would that cause any pressure changes since it’s a larger version of the pf48 filter?
Not an a-hole, it's genuine feedback. The one thing I have heard about Jasper is that they are great with their warranty... which to be fair, is accurate in my experience. They shipped out a non-AFM engine within 48 hours of the rocker arm diagnosis. That being said, the only way to have a reputation of "great warranty" is if your product consistently does not survive for 3 years/100k miles.Not to be the a-hole here but jasper is crap.
My workplace fleet mechanics have to put them in and they dont last 10-15-20k. Opening them up they have found that although its a fresh looking motor on the outside, internals are a mess. Granted these are Ram trucks (Dodges) not GM but i cant see them being any different. It doesn’t take much to steam clean a motor, slap some stickers on it and call it rebuilt. The mechanics just recently told me jasper is blaming them for the ‘rebuilt’ engine failures and won’t warranty them unless a 3rd party of their choosing installs them. Im not talking about 2-3 engines.. these guys have done upwards of 40-60 motors on our vehicles and they just dont last. (Apparently Ram had engine isssues from 2014 up)
I would get your warranty claim in, hopefully get another engine then start looking for another motor on your own and drop it to a mechanic you trust and let them freshen it up for you.
My 2cents anyway
Good luck
An idea. Send an oil sample to Blackstone and see if your engine is eating itself. If not then you can address things in a more casual manner.Drove it into my ditch (not sure if enough) and added 2 quarts. Pressure went up a couple PSI.
Going to do the 500 mile oil/oil filter change with a AcDelco filter now and see if that changes anything.
If no change, picked up another GM oil pressure sensor just to rule that out.
Calling Jasper either way tomorrow morning
