- Joined
- Dec 31, 2025
- Posts
- 629
- Reaction score
- 600
Anyone go through a flap-roller carwash with the solid antenna? This burb is too big to wash by hand...
I swapped my factory antenna for a 6" stubby. Reception is fine and when the beast gets a flap wash to scrub the top, there's no antenna drama.Anyone go through a flap-roller carwash with the solid antenna? This burb is too big to wash by hand...
Good to know there is space to reach that back one.. I'm going to have to do mine someday..
Same bolts broken on driver side, plus a middle one on passenger side.
i took my antenna and laid it down horizontal under the hood along the side of the panel, i don't listen to the radio but when i first did it i tested it and didn't notice any differenceScrewed the antenna back in, thanks for the replies. Will replace with a stubby if it ever gets ripped off at the carwash!
I wish they did the windshield antennas still. Can u get those???Unscrewed my antenna so I could go through the carwash, but it ended up unscrewing the middle part of the base!
I think I can screw it back in.. but I'm epoxying the tab that broke on the cowl piece first..
Also a small piece of hood paint flaked off starting from a rock chip..
I know you can get them aftermarket. They stick on the inside of the windshield.I wish they did the windshield antennas still. Can u get those???
Make sure you use a thin bead of silicone around the edge where the inner and outer edges meet, along with some dielectric grease on the gaskets for the bulbs. Doing this will totally eliminate any gasket failure which would let moisture inside the lenses.Received my TYC headlamp and turn signal housings. Headlamps came with Osram bulbs, old bulbs were sylvania.
Waiting for Napa Auto to open tomorrow for turn bulbs, because I sure as shit don't want sylvania that autozone and oreillys carry.
Old vs new.
Turn housings had water and condensation. Passenger side sockets immersed and soaking wet.
They had moisture in them before I went to the carwash a few days ago.. And it hadn't rained for awhile..
I love how easy it is to remove the light housings! GM still had someone who cared back then..
Also the new housings have a cylindrical bulb shade inside that the originals did not.. That would be good for??? HID or LED bulbs?
