Dead spot in steering + discontinued part.
Roilux
Senior Member
Burbank, CA
2004 Tahoe LT, bought used, drove and handles well for 158k miles.
To regain that new truck feel I've replaced hubs, A-arms, bushings, tie rod ends, upper and lower steering shafts, steering shaft bearing and most recently the steering box and again for the upper steering shaft. All nuts and bolts torqued to spec. It rides great and steering is crisp once I get out of a narrow dead spot at TDC. It's a narrow dead spot but it has to go!
Upon pulling the top plastic cover off the steering column I can see a shaft wiggle congruent with wiggling the steering wheel. However, the end of that shaft that bolts to the upper steering shaft just inside the cabin does not wiggle. I now know where the play is. Whether it's the joint or telescopic shaft isn't known yet.
It has taken a minute to locate the shaft part #, Online searches come up dry. Does anyone have a lead on a new aftermarket shaft source or part number?
GM discontinued it, Rock Auto has none, etc .....
GM 26090770 Steering Shaft Assembly. (photo of shaft and shaft within tilt mechanism.
mikez71
So the play is in the steering column?
Sometimes I feel a suspension clunk through my steering wheel. Whatever is knocking, it can travel right up the shaft.. sometimes..
Roilux
Roilux
Senior Member
Burbank, CA
Yes, solely in the steering column between the steering wheel and the upper steering shaft. It has taken weeks to find where the dead spot remains as the steering improved greatly while replacing parts, but not quite perfect.
What you've described is usually eliminated by replacing these two steering parts.
mikez71
@Roilux might need to buy a used steering column?
Borgeson makes a beefy aftermarket setup; I have no experience with it though. https://www.borgeson.com/99-08-Full-Size-Chevy-GMC-Truck.html
BTW - keep an eye on that Dorman bearing if that screenshot is from your order history. Mine fell apart in less than a week. Similar reports seen elsewhere.
Good to know, the genuine GM bearing is only $1.10 more than Dorman at Rockauto..
That's a bit more for the Borgeson.. I like their u-joints, but wonder if the vibration reducing coupling is necessary..
Wonder what it would take to get Borgeson to make (or just rebuild the everlovin shit out of) our GMT800 12.7:1 steering boxes?
Their OBS steering box is $520, and you would think NBS would be a bigger market..
Roilux
Roilux
Senior Member
Burbank, CA
Hello fellow Prime shopper. :)
I've already replaced the upper intermediate shaft twice. The ULTRA-POWER unit from RA became sloppy within 3k miles and was replaced last week with a stout Doorman unit. I have an AC Delco bearing in my '04. The Doorman unit was in my '01 and did well for the three years it was in there.
The shaft I'm doing the deep dive on is inside the steering column and resides entirely inside the passenger compartment. Note that it has splines at one end that the steering wheel mounts on. So far, no aftermarket units have been found online. :(
Roilux
Roilux
Senior Member
Burbank, CA
I installed a Plews Edelmann steering box a couple days ago and really like how it feels. It also revealed the upper intermediate shaft had worn out prematurely. Replacing that led to the discovery of the steering column shaft I'm searching for. That's the only component remaining that has play in it.
Roilux
Roilux
Senior Member
Burbank, CA
Pulled a steering column today from PYP out of a '06 LT to examine, possibly dissect or determine paths to swap entire columns, swap parts or rebuild a shaft if needed.
I have noted there are two Torx screws on the plastic joint inside the column that could possibly be tightened.
Roilux
Roilux
Senior Member
Burbank, CA
When tightening the T25 Torx screws inside the column, it only tightens the joint and increase steering wheel turning resistance. The play remains the same. Sooooo, scratch that from the playbook. Should you have really light steering with no play and wish to increase turning resistance then pop the top column cover and give each Torx a 1/4 turn. (last photo in this post)
Now that I have the column essentially stripped, the photo in post #1 of the shaft with tilt mechanism vs bare shaft needs further consideration. Whatever I do once will be repeated once more in order to swap shafts. I'd really like to avoid messing with the clock spring, layers of orientation and an obscene amount of electrical connections, but alas, I'm on a mission.
Roilux
Roilux
Senior Member
Burbank, CA
I'm leaning towards shaft removal from the column. There are far less electrical connections to futz with if I can leave the vehicle's column in place and slide its shaft out.
A 'U' shaped bracket needs to be fabricated to compress the stout spring behind this plate in order to remove the retaining clip. The threads on the shaft and steering wheel nut should do nicely to apply uniform pressure since none of the steering wheel locking plate removal tools I've found appear to be compatible.
Roilux
Roilux
Senior Member
Burbank, CA
Speaking of lower shaft bearings, once I get this column shaft business sorted, here's the final parts canon upgrade to achieve steering nirvana.
Do I need it now, no. Do I want it, yes.
Wolf Engineering lower steering column bearing.
www.wolffeng.com
mattbta
Frisco, TX
www.wolffeng.com
Nice, looks like they have one that accommodates the position sensor mine has. I even replaced that when I was chasing some issues!
mikez71
Wow, at only about 2x the cost of the stock GM part! That's a nice part!
Which models have the steering column sensor, and which don't?
I have disabled my Z55 autoride, so *if* the steering sensor is only used for that...
I wouldn't mind deleting the sensor, if possible.. ? (And not have to maintain sensor alignment, and save $6)
If not, I wonder which sensor I have.. wide, narrow, extra narrow, or disk.
mattbta
Frisco, TX
Per gemini:
The RPO code you are looking for is JL4, which stands for Control, Active Brake (commercially branded by GM as StabiliTrak).
Because the StabiliTrak electronic stability control system relies heavily on knowing exactly where the driver is aiming the vehicle versus where it is actually sliding, the Steering Wheel Position Sensor (SWPS) was added exclusively to GMT-800 trucks and SUVs equipped with this option.
Quick Tips for GMT-800 Owners:​
  • Where to check: You can confirm if your vehicle has this option by looking at the Service Parts Identification silver sticker inside your glove box and scanning the list for JL4.
  • Common Symptoms: If your steering wheel position sensor is failing on a JL4-equipped Tahoe, Yukon, Suburban, or Escalade, you will typically see a "Service StabiliTrak" or "Service Traction Control" message on your dash, accompanied by Diagnostic Trouble Code (DTC) C0710.
Roilux
Roilux
Senior Member
Burbank, CA
Per gemini:
This is interesting. I have JL4 but no sensor and the end of the column. Being the third owner, I'll need to explore under the dash and see if an incorrect bearing had been previously installed before I replaced it.
To date (4 years now) no codes, no lights and no DTC. StabiliTrak light is operational when button is pushed.
Marky Dissod
Just to be sure, use an excess amount of tire shine on your tires, get some on the treads, and go test your StabiliTrak ...
mikez71
Yes! No JL4 on my 2500!
How hard is that bushing to replace? Do you have to remove the column like charm.li says?
Or can you remove the upper steering shaft and get space to work?
I tried pushing/pulling on the ujoint in there, and don't sense any play... So not sure that is my issue..
Roilux
Roilux
Senior Member
Burbank, CA
Replacing the bushing isn't complicated. Turn your steering wheel 90º left and secure it from rotating. The nut you need to remove is now pointing straight down awaiting a 15mm socket to remove it. Separate the upper intermediate steering shaft from the steering column and push it aside.
Give the bearing a wiggle tug to pull straight out. I've replaced that bushing twice and did so by hand each time. Putting a new one in only fought me once. Extra lube everywhere won't hurt.
Reinsert the shaft, bolt, nut and torque to 37' lbs, or one good ugga dugga.
** If you need more space to work in, two nuts release the gas pedal assembly and removing three more nuts allows the rubber boot to release from the engine side of the firewall. My '01 was easy peasy while the '04 was easier with more space.
Before finishing this steering column shaft project I'm on, the existing bearing will be replaced for final time with a Wolf unit.
davesproblem
