Note.... The oil level sensor and vehicles equipped with it is insulated from the oil pan. The entire sensor including the threads is plastic.... So the switch inside doesn't connect to ground or anything, it just connects the two wires.
Excellent, thank you! So does that mean I can jumper pins 33 (oil level switch signal) and 24 (low reference) to provide the signal?Looks like oil temp and level in the sensor..
gm-techlink.com
I work with a bunch of electrical engineers (I'm a civil) and I was talking to one of them today about that sensor and its wiring diagram. We're thinking that, yes, it's variable so you get a range of temps, but the input to the oil level pin just needs to have a voltage (1-5v?). To put it another way, if oil level is good, switch is closed and it sends some voltage to pin 33. If oil level is low, switch is open and pin 33 gets 0 volts. Does that seem correct?Pretty much.. The only thing, it looks variable in the diagram to me..
I read a post where someone jumpered the wires to bypass a broken sensor,
BUT that was an older '02-'03 model and the level sensor looked like a switch in the diagram.
Worst case, you might need a resistor if it's outside the range the ECM is expecting?
Although looking at the sensor itself, it looks like a float and there isn't much range of motion, so probably still just a switch...
Here's some info on later model sensors saying RTV silicone in the oil can mess with the readings..
Low Oil or Add Oil DIC Messages – TechLink
gm-techlink.com
I don't believe my original LMG had an oil temp sensor, nor does the new L96. But maybe the 2013 caprice L77 that the tune came from did? As for adding oil temp sensor, what about a sandwich plate at the oil filter mount? Seems like the easiest option?I wonder what year they added the oil temperature sensor there. I know the 2003s only had two wires to the level sensor.
I'm thinking if your ECM monitors oil temperature, it's probably in the algorithm along with other sensors to control radiator fan speed, fuel mixture and overall performance.... And probably some form of limp mode if it gets excessively high. I would probably run a wire from the pin out for that, and mounted temperature sensor in a tee fitting along with the oil pressure sending unit.... Or you can mount one on the driver side of the engine, just above the oil pan lip towards the front. Adapters are readily available. (I use such an adapter to thread in a hose barb when priming a new engine, then remove the hose barb and put an NPT plug in the adapter. My '03 Hummer with the 6.0 does have an oil temperature sensor screwed in there for a gauge)
What's the wiring for the temp sensor? Is it two wire with one going to Low Ref pin 24 and the other going to Pin 23? Or does it need a 12v power source?Was doing some reading, read that starting in 2007/2008, the oil temperature parameter was added into the algorithm for calculating the engine oil life for the display on the dash.
So to keep this from screwing up that calculation (Which I wouldn't recommend anyone to follow.... 3500 to 5,000 mi max depending on how it's used).... I would go ahead and install an oil temperature sending unit in that port mentioned above. You'll get basically the same temperature reading right off the oil pump as you would get in the oil pan.
Yep, I'm going to do some testing and see if there is 5v where expected before I jumper anything. Thanks for the input. (pun intended!)Yes that seems correct.
Both other pins 23 & 33 should be + voltage, using lo ref to ground. The ECM senses the current through the positive pins is how I'm reading it. Since it is labelled 'oil lvl sw signal', I take it to mean it is a switch. But since it connects to middle of resistor, may normally have some resistance when closed? If connecting pins directly doesn't work, you could try measuring a sensor..
yep, I've been getting that "Low Oil Level" at each start on my DIC for a while now although its fullYep, I'm going to do some testing and see if there is 5v where expected before I jumper anything. Thanks for the input. (pun intended!)
Different operating system. It sounds like it’s vey difficult/impossible to get them to work with a different OS. Probably also wouldn’t work with BCM and TCM.Why can't he do a L96 base file tune as a starting point?
Flashing a different OS will brick the PCM. Although I have read that doing a "Write Entire" will allow you to change OS without issues, I have never tried it myself.Different operating system. It sounds like it’s vey difficult/impossible to get them to work with a different OS. Probably also wouldn’t work with BCM and TCM.
Yep exactly what he’s going to do with tunercat. And yes, “time consuming” were the exact words he used too.Flashing a different OS will brick the PCM. Although I have read that doing a "Write Entire" will allow you to change OS without issues, I have never tried it myself.
Basically what needs to happen is you would pull the L96 tune file and do a "Compare File" with your original LMG tune file. The compare will show ALL the differences between the two. Then you go through and change everything over in the original LMG file, which can be time consuming, and then just save the altered LMG file and write it back to the ECU. At least that is how it works with HP Tuners.
Have you looked at the Express Van tunes? Those had the L96 and 6 speed. Not sure if that plays well with the GMT900 based SUVs tho?Different operating system. It sounds like it’s vey difficult/impossible to get them to work with a different OS. Probably also wouldn’t work with BCM and TCM.
