Build thread - LMG 5.3 to L96 6.0 swap
rdezs
Note.... The oil level sensor and vehicles equipped with it is insulated from the oil pan. The entire sensor including the threads is plastic.... So the switch inside doesn't connect to ground or anything, it just connects the two wires.
mikez71
Looks like oil temp and level in the sensor..
mikez71
Pretty much.. The only thing, it looks variable in the diagram to me..
I read a post where someone jumpered the wires to bypass a broken sensor,
BUT that was an older '02-'03 model and the level sensor looked like a switch in the diagram.
Worst case, you might need a resistor if it's outside the range the ECM is expecting?
Although looking at the sensor itself, it looks like a float and there isn't much range of motion, so probably still just a switch...
Here's some info on later model sensors saying RTV silicone in the oil can mess with the readings..
rdezs
I wonder what year they added the oil temperature sensor there. I know the 2003s only had two wires to the level sensor.
I'm thinking if your ECM monitors oil temperature, it's probably in the algorithm along with other sensors to control radiator fan speed, fuel mixture and overall performance.... And probably some form of limp mode if it gets excessively high. I would probably run a wire from the pin out for that, and mounted temperature sensor in a tee fitting along with the oil pressure sending unit.... Or you can mount one on the driver side of the engine, just above the oil pan lip towards the front. Adapters are readily available. (I use such an adapter to thread in a hose barb when priming a new engine, then remove the hose barb and put an NPT plug in the adapter. My '03 Hummer with the 6.0 does have an oil temperature sensor screwed in there for a gauge)
rdezs
Was doing some reading, read that starting in 2007/2008, the oil temperature parameter was added into the algorithm for calculating the engine oil life for the display on the dash.
So to keep this from screwing up that calculation (Which I wouldn't recommend anyone to follow.... 3500 to 5,000 mi max depending on how it's used).... I would go ahead and install an oil temperature sending unit in that port mentioned above. You'll get basically the same temperature reading right off the oil pump as you would get in the oil pan.
DaveO9
DaveO9
Vancouver, WA
I work with a bunch of electrical engineers (I'm a civil) and I was talking to one of them today about that sensor and its wiring diagram. We're thinking that, yes, it's variable so you get a range of temps, but the input to the oil level pin just needs to have a voltage (1-5v?). To put it another way, if oil level is good, switch is closed and it sends some voltage to pin 33. If oil level is low, switch is open and pin 33 gets 0 volts. Does that seem correct?
I don't believe my original LMG had an oil temp sensor, nor does the new L96. But maybe the 2013 caprice L77 that the tune came from did? As for adding oil temp sensor, what about a sandwich plate at the oil filter mount? Seems like the easiest option?
What's the wiring for the temp sensor? Is it two wire with one going to Low Ref pin 24 and the other going to Pin 23? Or does it need a 12v power source?
mikez71
Yes that seems correct.
Both other pins 23 & 33 should be + voltage, using lo ref to ground. The ECM senses the current through the positive pins is how I'm reading it. Since it is labelled 'oil lvl sw signal', I take it to mean it is a switch. But since it connects to middle of resistor, may normally have some resistance when closed? If connecting pins directly doesn't work, you could try measuring a sensor..
DaveO9
DaveO9
Vancouver, WA
Yep, I'm going to do some testing and see if there is 5v where expected before I jumper anything. Thanks for the input. (pun intended!)
donjetman
yep, I've been getting that "Low Oil Level" at each start on my DIC for a while now although its full
DaveO9
DaveO9
Vancouver, WA
Ok time for some tuning talk.
My tuner used a base file from a 2013 L77. L77 is an aluminum 6.0 block used in that era of Caprice PPV (and some Holden cars) – 10.4 CR, with AFM, but no VVT. Although HP and torque are similar, it’s a bit different than my iron block L96 – 9.6 CR, no AFM but with VVT. Tuner used this as a starting place since it has the same OS as my original LMG tune, whereas the L96 files did not. The engine runs great with a smooth idle and no stumbles anywhere I’ve noticed, but there are at least three issues I’m seeing with the L77 tune: 1) it’s running rich. Getting persistent P0172 codes for both banks. 2) the issue described above with the fake oil level warning, 3) I really would like to have VVT enabled. I have the stock L96 cam, I might as well get the benefit of that system.
After talking with tuner, we’re going to abandon the L77 tune, go back to my original LMG tune (AMF already tuned out) and then bring in all the appropriate tables and values from a 2013 L96 tune. My tuner uses both EFI Live and TunerCat. We first talked about me using the free version of EFI Live to make the mods to the LMG file, but I don’t believe the free version allows me to mod and save. So we are now at him making the mods in TunerCat. I’ve worked with him for 10+ years, 3 different vehicles, and he’s charging me a very fair price. (We also discussed doing an email tune through BlackBear but that’s outside of my budget at this moment). I believe I’ll end up with a mostly stock L96 tune, with some torque management parameters modified. He previously tuned my trans – the only change there is I’m asking him to allow lockup in 4th as well as 5th and 6th, since I have a new, upgraded Luk TC. There may be some shift table recalibration required for that.
Does all this sound OK? Any red flags?
kbuskill
NE. FL.
Different operating system. It sounds like it’s vey difficult/impossible to get them to work with a different OS. Probably also wouldn’t work with BCM and TCM.
Flashing a different OS will brick the PCM. Although I have read that doing a "Write Entire" will allow you to change OS without issues, I have never tried it myself.
Basically what needs to happen is you would pull the L96 tune file and do a "Compare File" with your original LMG tune file. The compare will show ALL the differences between the two. Then you go through and change everything over in the original LMG file, which can be time consuming, and then just save the altered LMG file and write it back to the ECU. At least that is how it works with HP Tuners.
DaveO9
DaveO9
Vancouver, WA
Yep exactly what he’s going to do with tunercat. And yes, “time consuming” were the exact words he used too.
strutaeng
Dallas, Texas
Have you looked at the Express Van tunes? Those had the L96 and 6 speed. Not sure if that plays well with the GMT900 based SUVs tho?
DaveO9
DaveO9
Vancouver, WA
Yep, they have the same OS issue as the pickups. But another option tuner and I discussed was replacing whole ECM with one from a van. I was messing around with AI and found that although most of the vans had 6l90 trans there were some that had a 6l80. But with a different ECM you still have the risk of it not playing nice with BCM and TCM so we decided to stick with my ECM.
DaveO9
DaveO9
Vancouver, WA
Been a while since I've posted, and I haven't done any work on the tune for the last week plus - family stuff - HS graduation, picking up another kid from college, etc.
Heading back out to see the tuner this afternoon, tho. This will be an interim tune - basically the fueling parameters for a stock L96 imported into the current L77 tune it's currently using. Chief goal will be to get rid of the P0172 rich code.
Going back to my original LMG tune and importing everything needed from L96 is a bigger job than both tuner and I expected. Lots of tables don't line up exactly with different axes and such. If we can get the current L77 tune running good without codes, then now I'm wondering if it would make more sense to keep that tune? Since it's the same OS as my LMG that has VVT, I think the VVT tables are in there, they would just have to be activated? Then I could just populate those tables with values from the LMG tune (since the table axes and scaling will match exactly) and the L96. From what I've read, it seems like most of the VVT tables it will be OK to use the LMG values, with the exception of the three or so tables that actually provide the cam phasing angle. But, I am not experienced in this stuff, so there may be a new plan after this afternoon.
DaveO9
DaveO9
Vancouver, WA
Update on the tune situation. Still running the 2013 Caprice PPV, L77, tune file. It's about as good as it's going to get. Had a few cycles with the tuner and a few issues to resolve. But now I can drive it consistently and not get a CEL and it's behaving fairly well, for using a tune from a significantly different car and engine.
The delay has been finding the correct tune file, especially in either a EFI Live or TunerCat file format - the two platforms my tuner uses. Weeks ago as this project started it seemed pretty simple - just find a file for a vehicle that used the L96 engine and also used same ECM and Op Sys. Express vans, 2500 Silvy's, 2500 burbs, etc. But as the project progressed, found out it's not that simple. The 2500 Silverados from that era had moved on to the E78 ECM, not the E38 like my Tahoe. So, I was becoming resigned to using the method described above: copying and pasting individual tables and parameters from an L96 tune into my LMG flash. I was going to do a lot of the work myself using the free version of EFI Live, but I wasn't super confident and thought there was a high liklihood I'd missing something.
Well yesterday and today, we found the unicorn: although the 2500 Silverados moved on to the later E78 ECM, the Subs and Yukon XLs kept the E38. (you can tell the difference by number of connectors. E38 has two whereas E78 has three) Tuner told me that to get a file from TunerCat you need a VIN. Well, I found a 2013 Yukon XL 2500 for sale and the ad gave the VIN. Tuner took that to TunerCat, and yes! It uses E38 and has an identical OS#. $40 from TunerCat plus his fee and it will be good to go. Since it has the same OS, all the engine parameters and tables can be swapped en masse using the "segment swap" method. Much easier.
The actual reflash will probably not occur till next week, but I'm excited to see what this engine can do with its proper tune file and VVT active.
DaveO9
DaveO9
Vancouver, WA
Finally to the 90-95% satisfaction level on the tune. It's been a journey.
Tuner and I spent a lot of time trying to get the L77 tune to work because of the mismatch with ECM and Op Sys between the L96 trucks and my LMG Tahoe. If there's one thing someone with plans for this same swap can take from this, is don't do this! The problem with the L77 is it doesn't have VVT whereas my original engine, as well as L96 I installed, do. Tuner and I both assumed the cam would just stay in it's "parked" position and it would be fine, but no. As I put more and more miles on it, it started running worse and worse, with it getting to the point it would buck and backfire and miss under load. It was bad enough that it ruined one spark plug - I'm thankful nothing worse happened. I think the cam drifted away from it's parked position, since there was nothing controlling it. So if you're keeping the physical VVT cam and related, you need to have a tune that can control it. If you're switching to a fixed cam, the L77 tune may be a good way to go, at least as a starting file.
We should have started with a proper L96 tune file, but the problem was finding one that would work with my ECM. As described in posts above, we had both an operating system problem and an ECM problem. But also as described in post before this one, we discovered the unicorn: the 2013 2500 burbs/yukon XL stayed with the E38 ECM and they used the same OS as my original.
Once we had the slightly modified (typical basic tuner mods) L96 file flashed, we thought it would be smooth sailing. It largely was, with one exception. On my first drive with that tune, it ran well until I punched it going up a hill. At about 60% pedal it abruptly went into limp mode. Ruh roh. Turns out, there is some background math in the E38 that looks at air flow compared to throttle application. Since it saw more air than it thought it should at that point (6.0 pulls in more air than 5.3, especially at higher throttle angles), it thought there was a runaway throttle and choked it off. After some internet sleuthing we found that instead of using the electronic throttle tables from the 2500 suburban, we needed to use the original Tahoe LMG tables. Switched back to those tables and all is well. Basically, the heavier 2500 trucks have a more direct throttle application - 50% pedal is close to a 50% open throttle blade. The LMG tables are less direct (lighter weight vehicle) and the L77 tables (Caprice) have even less throttle response. (there was an interim period where I had the L96 tune with the L77 throttle tables - very poor throttle response, awkward to drive.)
Last remaining tune issue, (for now, at least) is a too high idle speed immediately after cold cranking. It jumps up to between 1600-2000 rpm for a few seconds right after cold start up. I believe this can be resolved by just reducing the values in a cranking air flow table. Want to wait a couple weeks before I bug the tuner again just to make sure there's nothing else.
ScottS-Michigan
