Anyone done their own Transmission Pan drop and filter change on a2021+ Tahoe
TrucksNStuff
All I can find are youtube videos and write-ups about the silverados, but nothing for the Tahoe. I've got a 5.3L Z71 with the 10-speed transmission. I bought all the parts but when I went to get started I couldn't even do the first step: The Tahoe seems like it has way less clearance than the Silverado's between the transmission and frame to get to the bolts needed to drop the exhaust to get enough room to get the pan out.
Has anyone done this themselves and had a similar experience? I read a forum post about a 2019 Escalade where the guy just wiggled the pan right out, but others report that only works for some people. Is my only option the dealer? My dealer wants to do a full flush with BG fluids, neither of which I need or want. Just looking for a filter change, cleaning the magnetic debris off the magnets, and filling back up to proper level with ACDelco equipment.
No videos or how-tos or write-ups that I can find specific to the 2021+ Tahoes.
Boston
Nope… my dealer quoted me $1050 to do a filter and fluid change. Both sides of the exhaust need to be disconnected, plus the removal of the O2 sensor I believe on the passenger side. Plus refill has some specific requirements at temperature.
jerry455
There is a whole thread on here about this. Yes, I did mine on a 2021 Suburban. The pick up and the Utilities are the same. I did not drop my exhaust but I unbolted the trans and lifted while pulling down the rear exhaust and got the pan out. It is tight. There is a lot of information on getting the level correct. I measured what was removed and refilled the same amount.
T
TrucksNStuff
By unbolting the trans you mean You unbolted the two transmission mount bolts on the crossmember then lifted up the whole transmission to get clearance?
Boston
You said you did all this and it was still tight to get the transmission pan out… how did you get the pan back in with a new gasket
jerry455
Yes, loosen trans mount. It is tight. Once it is in position, you can move the gasket around and put it in correct oreintation.
jfoj
I did this, installed a new aftermarket PPE pan with a drain so I can perform drain and fills without dropping the exhaust. Removed the drivers side O2 sensor and dropped the exhaust down a few inches from the manifold. There is a flex coupler that allows the Y pipe to be dropped. I do not think I could have slipped the newer PPE pan back in if I jacked up the rear of the trans as the PPE pan is deeper.
I have this info in a thread about upgrading the valve body with the NextGen parts. Search my user name.
jerry455
How do you like the PPE pan? Been thinking of adding that also. It has been 20,000 miles since the new trans was installed on my 2021 in Feb. 2025, and thinking about fluid and filter change. If I do that I will also install better pan.
dbphillips
Really kind of criminal they didn't include a drain plug pan, as much as replacements cost, especially given the gassers are most of the build volume. That said, Babymax ftw!
jerry455
I don't think you will find many manufacturers that have a drain plug in their trans pans anymore short of HD trucks. I can't recall any in many years.
Boston
Yes a transmission drain plug would be helpful in some situations, but the real problem is the GM design engineers that routed a crossover pipe under the transmission pan probably causing increased temperatures to the transmission and making it more difficult and costly to do a filter and fluid change
JKeller
I would give an independent shop a try. Mine charges me about a third of that for the tranny filter and fluid.
jfoj
Even if you do not do your own work, suggest you get an aftermarket pan with a drain plug installed if you have fluid and filter changed, then you can perform an easy drain and fill without the filter every 15k miles. Anything to lengthen the transmission lifespan would be wise.
West 1
If your truck is up on Jack Stands for this job you can run a ratchet strap from the exhaust down to the jack stand and use the strap to gain extra room between the tranny pan and the exhaust. As already mentioned above you probably need to remove the trans mount bolts and jack up the rear of the tranny also. I have used a smaller 1 1/4” ratchet strap and it was strong enough to give me the extra space needed. Don’t get carried away and start bending your exhaust.
jfoj
Sorry, just saw your question about the trans pan, I like it very much, great quality, holds a bit over 2 extra quarts of fluid and will give protection in case you run over something, the OEM pan is way too thin and will not hold up to any impact. Would use this pan again in a heartbeat.
Escalade2007
