07 Tahoe LTZ gas in the oil
mikez71
Fuel trims are negative at idle, climb up upon acceleration.
What kind of trims are we talking about?
Seems like fuel could only get in from the injectors (injecting too much, since they aren't leaking?)
Or being drawn in from the evap.. (which you said did not smell like fuel.)
West 1
Since you already have a set up to supply 100 PSI fuel. Get an injector electric connector, OReilly sells them, set your connector up so you can apply 12V power. With the fuel pump pressurized you can test your injectors one at a time and see the fuel spray pattern.
If they don't have a good spray pattern clean them and try again. There are Youtube videos showing how to clean injectors. It takes time but is simple. Or take them to a shop for a professional cleaning.
Hellacious tahoe
Hellacious tahoe
Short term trims were around -2 at idle. Long term trims were in the positive 5's if I remember correctly. I did smell the vapor return line next to the solenoid, no smell of gas.
Hellacious tahoe
Hellacious tahoe
I was tempted to apply 12 volts to the injectors, but refrained wandering if they work at 5 volts instead. I have the setup out, so I can still do it. At this point, with no visible injector leak and the fuel vapor return line dry, I'm starting to think of sabotage. Last fall I took the truck to a shop for safety inspection. I was mistreated at that place and walked out with a 14 point list of defects that looked more like an intentional flunk. Returning home was normal, no noises at all. I parked the truck and a month later I idled the engine, it was cold and some noise came out, like that of a bad pulley. I turned off the engine and a month later I idled it again, this time made more noise and the low oil pressure warning came up, but no engine light. I turned off the engine and left it alone until this spring, when I noticed gas smell on the dipstick. I drained the oil and it was very diluted. The new oil does not smell like gas, but I have not run it for longer than a couple minutes, with the exception of one spin around the block, which felt just fine until the low pressure oil warning came up. So here I am, with a riddle and unable to register the truck.
mikez71
What about fuel trims driving around?
Is it possible the new fuel pump fixed the gas in oil, but now you have a seperate issue? (and/or new injector o-rings will help with trims once installed)
Low oil pressure plus noise is not a great sign.. Hopefully seperate coincidences.. Pressure must have been in single digits to trip the warning.
And if just a faulty sensor, shouldn't cause noise. Might be worth overfilling the oil if it's the pickup tube o-ring..
If you have that 14 point list, post it.
It does sound like a lot, but it's also hard to believe they would go through the trouble to sabotage your truck..
(maybe the wrong pump threw things off enough that they suspected other issues, and had to list all the possibilities? idk)
mikez71
First question:
How was the previous generation fuel pump rigged?! The 07+ use the fuel pressure module to regulate the pump duty cycle via PWM, right?
Looks like '07 has no FPCM, just power to it, must have a regulator, but since some hose wasn't connected, maybe was running at higher pressure?
Looks like FSCM was added in '08.
Hellacious tahoe
Hellacious tahoe
Low oil pressure plus noise is not a great sign.. I believe the pressure must be in low single digits to turn on the light at idle.. And if just a faulty sensor, shouldn't make noise. Might be worth overfilling the oil if it's the pickup tube o-ring..
(maybe the wrong pump threw things off enough that they suspected other issues, and had to list all the possibilities)
I seem to have dual separate issues, both critical. Im handling the fuel in the crankcase first. Its just coincidence that the fuel in oil came after the ispection shop experience. The car drove 250 km when I bought it, no issues.
mikez71
OK, but you said oil smelled like fuel when you got it home, double flushed it and it smelled like fuel again later. (maybe after shop visit) Driving 250km doesn't mean there was no fuel in oil?
(unless you mean shop sabotaged your oil pressure)
But it sounds like you still have fuel in oil after new fuel pump, so who knows.. things can suddenly give up..
Did you change oil filter the last time you changed oil? (that might leave enough gassy oil?) Or if your rings are toast or cylinders are glazed, perhaps mixture is blowing past? idk
Hellacious tahoe
Hellacious tahoe
After the 250 clicks coming home when I bought it, I drained the oil which came out black and thin, much like strong cofee. I dismissed it as old 5w30 or 5w20 and I did not smell it. I wander if the engine would have been able to run 250 clicks with diluted oil. I then flushed it twice, then poured in new 5w30 along with a new filter. Months went by while I was doing brake work, abs and changing the rear wheel seals plus some cosmetics. It was the end of the fall when I took it to the inspection shop. Winter came and one cold day it made what sounded like pulley noise when I started it. The noise disappeared a few seconds later and I let it idle for a few minutes. A month later it did the same thing, plus flashed a low oil pressure warning. I stopped the engine immediately. Another 6 weeks went by and I took the truck out of storage, parked it in the garage. This is when I checked the oil and found it to be diluted. I was going to replace the oil pump and the o'ring at the pick up tube, but the oil dilution has stolen the show.
Hellacious tahoe
Hellacious tahoe
I also wander if my truck has the AFM high pressure pump that is known to leak fuel into the crancase. As far as I know, 2014 was the first year with that system, but Google AI insists that my 2007 truck has it. I haven't reinstall the intake yet, just in case I have to remove the valley cover to get to the high pressure fuel pump if the truck has one.
Hellacious tahoe
Hellacious tahoe
Put a good scanner on it and read the short- and long-term fuel trims. It may be overfuelling.
One cause of this -- if it's a flex fuel engine -- is that the PCM thinks it's running fuel with a high ethanol content (E85), and commands more fuel.
A good scanner will show you what it thinks the ethanol/alcohol percentage is, and that should roughly match the ethanol content of the gas you're putting in the tank (e.g., E0, E10, E15, E85). If you find out that there's a wild difference, the same scanner will likely allow you to reset the ethanol percentage, and the long-term fuel trims.
Please let us know what you find out. Video below for info specific to the cause and remediation.
The truck is not driveable now, as I removed the intake to test the injectors and replace the oil pressure sensor. Will report on fuel trims as soon as I can take a spin. I wander if disconnecting the battery will reset the ethanol percentage data and the fuel trims.
mikez71
I also wander if my truck has the AFM high pressure pump that is known to leak fuel into the crancase. As far as I know, 2014 was the first year with that system, but Google AI insists ...
Not aware of any AFM high pressure pump causing fuel leaking into crankcase.
Perhaps you are confusing AFM high volume oil pump with direct injection high pressure fuel pump.
2014 SUV's do not have direct injection, perhaps the 2014 trucks do. Your '07 also forsure does not.
Unplugging battery should reset fuel trims, and I imagine ethanol % as well? (maybe someone else can verify)
Google AI sure can sound convincing.. I thought it was onto something with my P0101 code, it sounded very sure of itself, and it made logical sense (not bad) But in the end it was incorrect and not any advice I've gotten anywhere else. I think it scraped too many injector cleaning business web sites.
(I haven't solved it yet.. Thought I logged it today, but it was just a knock sensor CEL, so I still have a few checks to make..)
I don't think the ethanol content and long-term fuel trims get reset with a battery disconnect. Short-term trims get reset on an ignition cycle.
If ethanol content was to reset, think about how crappy the engine could run if it had to figure that out every time the battery was disconnected. Should be able to read the "calculated" ethanol content without starting the engine, so anytime is good.
Hellacious tahoe
Hellacious tahoe
I wander what happens with the injectors when their cylinder gets deactivated. Does the ecm shuts them down? I was also looking at a DOD deactivator module that plugs into the obd socket. It is also supposed to regulate the fuel injection patterns for increased fuel economy. Has anyone had any experience with the electronic DOD deactivator?
DOD isn't the technology used in the GMT900s, it's AFM (Active Fuel Management).
Marky Dissod
I wonder what happens with the injectors when their cylinder gets deactivated. Does the ecm shuts them down?
YES, that's the whole point, to shut down the fuel to (as well as closing both valves of) cylinders 1, 4, 6, & 7.
I was also looking at an AFM deactivator module that plugs into the obd socket. It is also supposed to regulate the fuel injection patterns for increased fuel economy.
So far as most of us know, all they do is prevent the ecm from using less than 8 cylinders; they are not known for altering fuel injections patterns.
If this is not the case, please show info to that effect.
mikez71
Just as crappy as when you get to empty and fill up with alternate gas? Not saying they reset forsure, but I don't think it would be any worse?
Last post about an AFM deactivator was something about them dying, and another where they couldn't pass emissions testing until they unplugged it. I feel confident in saying, it's the less preferred option.
Well, in order for 2005+ years (without the physical fuel content sensor) one must refuel properly:
  • TURN THE KEY OFF WHEN FUELING
  • ADD MORE THAN 3 GALLONS
  • DRIVE 7 MILES OR MORE
Yes, when going from E-85 back to gas and vice versa, it may run a bit rough when taking off from the gas station. But if the O2s are working properly it should smooth out shortly, absent any other issues. Stopping the engine shortly after fueling, and restarting later, may impact how well the system estimates the alcohol content.
My '04 with the physical sensor is accurate after about 2 miles, or even less. I've watched the alcohol content and fuel trims on a scanner after a fueling event that met the above criteria.
EDIT: IIRC some of the GMT900s have an updated calibration to help with the virtual alcohol calculation. However, there are times when the virtual sensors don't work properly due to aging or defective O2 sensors.
Hellacious tahoe
Hellacious tahoe
Thx for that piece of inte Mike, in my ruminations, failure of the ecm to deactivate the injectors of the 1,4,6 &7 cylinders could be the cause of my gas-in-the-oil tragedy. By the way, I measured the resistance across the pins on each of the injectors. I got 3.5 to 4.5 ohms across the team of injectors. In another wavelenght, I ordered one DOD deactivator from Temu and the listing description stated that fuel patterns are optimized. I may have swallowed bait, hook, line and sinker huh? Ill take a screen shot for you guys and eventually will be able to report the results.
a1parrothead
