Charlie207
Cleaned the contacts inside the accelerator pedal assembly, and there was just a tiny bit of gunk (oxidation?) on the contacts.
Remove connector from assembly.
Remove two T30 mounting screws. (assembly is now detached from vehicle)
To clean:
Remove four Phillips screws on cover (leave the two T30 screws that are also present on pedal assembly).
Remove cover, and remove small board (it's not retained by anything other than the small spring contacts).
Spray contact cleaner on everything and clean with Q-tips (I used DeOxit, but I'm sure MAF, electronics cleaner, iso-alcohol,etc. works fine)
Let dry and reassemble.
No pics... the dog was playing Tetris on my phone.
To clean:
