Eman85
Didn't read all of your posts but I have replaced a few starters on these trucks. I use a reman #6449 starter, it's the small starter. Be sure you have the correct bolts for the correct starter. life was good back in the day when starter bolts were either long or short for a Chevy. When the smaller starters came out they take a special bolt that's just a little shorter. This starter is used on small and big block Chevy trucks, I use the same starter on my drag car.
GMT800 2005 Tahoe Z71
Navy Supporting Member
I have no idea. No shims were installed with the previous starter. If the next one doesn’t work I’ll have it towed to a decent shop that can figure it out. I don’t even know how to inspect the teeth on the flywheel.
The bolts inspection, recommended by @Eman85 sounds like an idea. When I was in shops, to see the starter gear line up on the flex plate, we painted the starter drive teeth.
the 18th letter
Northern New Jersey
IMG_2613.jpegThat’s what came out of it, 6449. Going to get the OEM part and return this WAI brand they sold me :( Will make sure the bolts match as well before reinstalling.
the 18th letter
Northern New Jersey
My poor baby probably hasn’t had an undercarriage wash (proper with a cleaner. I will run the sprinkler under it at end of winter) since the year I put the starter in. New starter in and she’s firing right up as she had been. During the detailed inspection I noticed one of the connecting wires was showing metal. I switched that out and swapped the WAI for a re manufactured AC Delco and I’m good to go again for now.
LsHart
Senior Member
View attachment 480274That’s what came out of it, 6449. Going to get the OEM part and return this WAI brand they sold me :( Will make sure the bolts match as well before reinstalling.
Question. Does ur vehicle have the turn the key once and it will turn over? Or do u have to hold the key over? I haven't read all the post either. Just spit balling.
the 18th letter
Northern New Jersey
After a few trips with the new starter I’m inclined to think it may have been the frayed wire all the time. I used to get a slight shock at times when opening the driver door. When I say slight, it was more static like than an actual electrical shock. LSS I’m not getting static shocked anymore. New starter didn’t work at all once I really disturbed that wire before checking it and replacing. As mentioned 10 years is a good run for a starter so even if it was the wire, it’s not a totally wasted parts canon shot. At least that’s what I’m telling myself lol
th3 shifty
Utah
Got my tune from Blackbear. They corrected the speedometer (4.56 gears 35” tires) raised the speed limiter to 100mph, tuned for 91 fuel, adjusted shift points in trans. It made a huge difference is drivability. Woke up the truck in all the right places, and now I actually know my correct speed lol.
So huge shout out to BlackBear Performance. If you haven’t used them yet, you should. This was done on my 96 tahoe with 6” lift, 4.56 gears, 35” tires, rebuilt tranny with shift kit, headers, 3” exhaust
IRQVET
2 Door Owners Club
Tallahassee, FL.
I unloaded the parts cannon . . . (I don't have pics of everything)
Over the past 3-4 weekends:
New 15 piece Front Suspension Kit
New Shocks
New Grounding Straps
New Body Control Module
New Brakes (Calipers, Rotors, and Pads)
New NBS Brake Cylinder Upgrade
Eastwood Rust Reformer on the frame and rear axle
New A/C Compressor (Air drier and valve)
Replaced the transmission fluid (and filter)
Replaced the Rear Diff Fluid
How I'm justifying it in my head, as even with $2k in parts, that about equal to 2-3 truck payments on a modern vehicle. Except I own mine outright and have for 23 years.
I do have another $2,500 planned on stuff I want done, before we move onto paint next year.
IRQVET
2 Door Owners Club
Tallahassee, FL.
I unloaded the parts cannon this week (again).
Parts Order this week: (LMC and RockAuto)
New Grill
New Headlights
New Distributor
New EGR
New Bumper filler
New Alternator
New Refrigerant Lines
New A/C Condenser
About $1,100 worth of parts. Still cheaper than a new truck payment, lol.
Had to grab a used tire today because I got a sidewalk sidewall hole. 70 bux plus tax for a used Michelin what in thee duck is going on out here. NYC is a money pit.
Not much cheaper around me--central Jersey--for a good/decent used tire. Did the price include mounting, balance and leaving the old tire?
the 18th letter
Northern New Jersey
Tire is def in good condition I will say that. Price was all in left the old tire, balanced and mounted. I hadn’t bought a used tire in 4-5 years so it was sticker shock, with the taxes it came out 77 and some change.
kikeap
