09+ Hybrid cluster in 08?
langsbr
While I know the non-hybrid clusters will work fine from newer years into older trucks, will the hybrid cluster work? I see the coolant temp gauge is replaced with an efficiency gauge, but I was curious if it would simply function as a coolant temp gauge and everything else would work the same. Primarily looking to get the added features in the DIC, like oil pressure, etc.
mikez71
Interesting, so you can put the later cluster into earlier trucks? I wonder if the opposite works (minus gear display)
No idea about hybrid..but I doubt the efficiency would show coolant temp.
Oil pressure can be displayed with the BTDieselworks AutoSync device if you are looking for an alternate option.
L
langsbr
Only the same generation - 07 -14. The 09+ gives oil pressure and that's what I want on the DIC, primarily for WAF. Have a hybrid cluster lying around so was hoping it would just 'work' but was hoping for confirmation before plugging it in.
kbuskill
NE. FL.
You should try it and then post back in here with your results, then we will all know.
j91z28d1
definitely worth a try
1948Buickroadie
