4 Piston Big Brake Upgrade from 2019-20
MrMonte
Thanks! Also, why a 6.2? Aren't they having hella problems with the 6.2s? Honest question, I don't have an opinion one way or another.
I'm using an LS3 6.2L on my 73 Camaro so no DOD/AFM to fail. All aluminum so less weight up front and easy to get 500hp our of them while retaining great drivabilty and should get around 30mpg on the hwy in my 73.
My 2018 Yukon Denali had an AFM lifter failure at 88K miles so I deleted the system and at 115K miles with more power & better mileage.
My 2014 SS Sedan has almost 140K miles on its 6.2L LS3 and runs like new.
S33k3r
Dallas, Texas
Nice! where do you get those LS3 aluminum blocks? And is it possible without ransoming planet Earth to pay for it?
MrMonte
I watched auctions for 14 months before buying a 2011 Camaro 2SS for it's LS3 6.2L & 6 speed manual. Paid $6,400 but was too nice so I'm driving it now. 4 months later bought another 2011 Camaro 2SS for $5,300 then sold over $3,000 in parts leaving me with a great running LS3, 6 speeds manual trans, power heated leather seats, console, brake & fuel systems plus complete wiring harness.
Here's the one I kept. Even came with the carbon fiber hood.
jaxscuby
Jacksonville, FL
Do you have a 2000, 2001, 2002, 2003, 2004, 2005, or 2006?
I am just concerned you didn't see that this thread is not for your 2016.
well the previous models are using basically same parts that I can use for 2016.
the parts are from 2019-2022..so why wouldn't bolt on to my 2016.
S33k3r
Dallas, Texas
Fair enough. I know almost nothing about the later models.
bubbz22
I'm getting this mod completed next weekend, but did a dry fit this weekend. I'll be using these 17" wheels from the 2020+ Silverado and they clear perfectly, as I figured they would.
tc8510
TX
For the front calipers I machined some steel spacers that are 4mm thick to go between spindle mounts and the caliper to center it on the rotors. If you're going PPV 6 pistons up front i haven't done them yet.
POWER STOP Z362173 front pads
BENDIX SDR6885 front rotors
NUGEON 97P17504A/97P17504B front calipers
BENDIX SDR5729 rear rotors
POWER STOP Z261718 rear pads for SS Model
GM GENUINE 1722715/1722716 rear camaro calipers SS Model
And the link for rear caliper adapters
https://ctsvbrakeswap.com/products/...32273&pr_ref_pid=4290818211929&pr_seq=uniform
Finally getting around to upgrading the rear brakes with the parts listed.
My question is did you have to upgrade the brake lines and banjo bolts or easy swap over just change the washers?
buckwild27
EMT/First Responder Firefighter
Ohio
If you're using the camaro calipers on the rear you will need to use the banjo bolts for the camaro calipers. Everything else should swap over. I changed all my brake hoses because they were the originals, and I've had too many brake lines blow out on me. To not change them.
tc8510
TX
Thank you!
bubbz22
Has anyone tried 22” TBSS wheels with the 4 piston, with or without hump?
Have a set but would suck if they don’t work as love the wheels I have.
I realize this post was from a year ago, but it never got answered(unless I missed it). Anyone know the answer here on if 22" TBSS reps fit with the 2019+ brakes?
tc8510
TX
I finally got around to completing the full upgrade by installing the Camaro BBK. My question is, do I need to upgrade my Master Cylinder? Braking is fine under 60, anything higher, I notice pulling to the right. I have no sticking calipers. Everything is tightened down, lines are good, and the brakes have been re-bled. Am I missing anything?
nonickatall
Germany
It's hard to tell from a distance.
If the car pulls to the right, the braking force seems stronger on the right side.
This can be caused by pressure differences. This can, in turn, be caused by air bubbles remaining in the system, although you'd usually notice this if the brake pedal felt too soft.
It could certainly also be caused by a defective master cylinder, although this wouldn't spontaneously break with such a conversion.
Or by different friction values of the brake pad/rotor combination. Are your brake pads and rotors new?
I recently had a Mercedes B-Class belonging to a friend that I repaired and wanted to take through the TÜV which is the German technical inspection for safety. The TÜV criticized unequal braking values on the right and left. The discs and pads looked as good as new, so I focused on the rest of the braking system.
In the end, it was the brake pads and rotors that somehow had different values. After I replaced them, everything was fine.
Just swap the discs and pads from left to right. Then you'll notice if the car suddenly pulls to the left.
Funny story, when I went to the TÜV inspection for the third time - I obviously don't have a brake tester in the workshop - the TÜV inspector was too tough on the brake tester and ripped off my front bumper... I think I was the first customer to get an TÜV inspection with a ripped off front bumper. :Big Laugh:
buckwild27
Ohio
Are you talking about the rear calipers for a camaro they have bleed ports on front and back side. Also are the bleeder ports on the top side?
tc8510
TX
Yes it was properly bled and all pads and rotors are new. I haven't checked the master cylinder. My thought was that with being BBK on all four corners, I might need to upgrade to apply more pressure. But before I did any of that, I thought I'd check here 1st. I will look into your recommendation. Thank you!
tc8510
TX
It will be tight. I would shave it down.
BadDaddy2003
