Can I use the “better 2011” hydroboost?
treehan77
TYF Fiend
Crestview, FL
Can I use the 1781036 hydroboost unit (2011 MY only 2500HD)? Supposedly this is a better unit than the others. I have seen many use it on there gmt800 Duramaxes, just wondering if anyone has done it on a Tahoe or Yukon? Sounds like you’d just have to enlarge the hole to fit. My truck (05 Yukon) already has hydroboost, but it is leaking AGAIN. Replaced it a couple years ago, I hear this is is better.
Alex_M
Curious who says it's better - I've had 4 hydro boost gmt800s and never had an issue. Highest mileage is 270k and gaining. Sounds more like low quality reman units which is unfortunately. Quite common for anything reman at this point.
treehan77
treehan77
TYF Fiend
Crestview, FL
treehan77
treehan77
TYF Fiend
Crestview, FL
Nope, nobody seemed to know anything about this, I haven’t ordered a replacement yet, still leaking slowly lol
bgiff
I can confirm it fit my 2001 Suburban 2500.
It was a direct bolt on, I didnt have to mod anything. It does seem to provide easier (less effort braking). I also replaced the power steering pump with a Duramax version from PSC- Also a direct bolt on (with yer old pumps mounting hardware).
While I was at ut, I replaced all the power steering pump lines with Edelman Elite series for max durability!
The 2011 dmax master cylinder is a close fit- bolts right on but the two line fittings are ever so slightly smaller/different thread. My plan is to cut my lines, install the proper fittings, re-flare the old lines and enjoy the larger bore diameter MC. (38.1mm vs 37)
If you have a gmt-800 with hydro b, this is a no-brainer. Not only does it work better, the 2011 Oem GM hydroboost is significantly cheaper than the older model ones. When i bought it it was over 100 dollars cheaper on Rock.
strutaeng
Dallas, Texas
Nice to hear that!
My 06 suburban 2500 HB recently developed a leak. I ordered the 2011 after my budy (he did it to his 06 Duramax) mentioned it to me, and after seeing it was actually cheaper than a 06 HB replacement...
My order is somehow delayed on UPS, so it's a waiting game in the meantime.
Thanks for sharing your experience!
ivin74
05 NBS Nali
Htown, Texas
Curious what OEM unit you found? Everything I find is reman or aftermarket.
I bought it from GM parts direct like 5 years ago. They are probably not available any longer. The hydroboost on my Yukon still going strong after 50k miles.
Is this the part number you bought?
mattbta
Frisco, TX
ChatGPT planed out some steps (along with the T1xx 4 pot calipers)
Complete Parts List — “HD Hydroboost Conversion Kit”​
This list assumes you’re starting with a 2004 Tahoe (GMT800) that already has hydroboost, and you’re upgrading to a 2007–2010 2500HD (GMT900)–spec booster and master to increase assist and match the T1XX 4-piston brakes.
Core Hydraulic Components​
ComponentExample Part #Notes
Hydroboost UnitGM 178-1033 / ACDelco 52-7356Bosch HD hydroboost (2007–2010 Silverado 2500/3500HD)
Master CylinderGM 20861836 / ACDelco 18M26081.31 in bore, direct bolt-on to HD booster
Firewall GasketGM 15033968Optional but recommended
Pedal Clevis / PinReuse or adjust to match pushrod lengthPedal height fine-tune
High-Pressure Line (Pump → HB)Custom or Russell 641381 (M16 × 1.5 O-ring → -6 AN)Handles 1500 psi+
High-Pressure Line (HB → Steering Gear)Custom or Russell 648060 (M18 × 1.5 → -6 AN)1500 psi+
Low-Pressure Return (HB → Reservoir)3/8 in power-steering return hoseUse clamps
Return Y-/T-FittingDorman 800-640 or similarMerge HB + steering returns
Power-Steering Pump (HD spec)PSC SP1200-SAG / Cardone 20-6244F2.7 GPM @ 1600 psi recommended
Fluid Cooler (optional)Derale 13220 / Tru-Cool LPD4739Inline cooler on steering return
Reservoir (dual return)PSC SR146Optional upgrade if eliminating T-fitting
PS FluidGM P/N 89021184 (Synthetic PS Fluid)Do not use ATF
Brake FluidDOT 4 Low Viscosity (Valvoline or ACDelco)Best for ABS bleed
Adapters / Fittings Summary​
ConnectionThread / TypeAdapter
Pump → HB feedM16 × 1.5 O-ringto -6 AN male
HB out → SteeringM18 × 1.5 O-ringto -6 AN male
Steering gear return3/8 barbHose clamp
HB return3/8 barbHose clamp
Return merge3/8 Y / T fittingSmooth, no sharp turns
Fasteners & Hardware​
  • (4) M10 × 1.5 flange nuts for hydroboost firewall studs
  • (2) M10 × 1.5 bolts for master → booster
  • (4) New copper crush washers (banjos)
  • Blue Loctite 242
  • Zip-ties / P-clamps for line support
Installation Highlights​
  1. Bolt HD hydroboost to firewall using gasket.
  2. Install HD master cylinder; reconnect lines (may need gentle re-bend).
  3. Plumb lines per ASCII schematic from earlier (Pump → HB → Steering → Return).
  4. Check pedal height — pushrod free-play ≈ 0.010–0.020 in.
  5. Fill reservoir and proceed to bleeding sequence.
Bleeding Procedure — Power Steering / Hydroboost​
Goal: purge air from both assist circuits before touching the brake side.
  1. Fill PS reservoir with fresh GM fluid.
  2. Engine off: cycle steering lock-to-lock slowly 10–15×.
  3. Crack HB return fitting slightly; cycle again until fluid (no bubbles) appears.
  4. Tighten return, refill reservoir.
  5. Start engine for 5 sec, shut off, top up.
  6. Start engine, idle, and cycle steering gently lock-to-lock.
  7. Repeat until fluid stays clear, no foaming, and assist feels smooth.
  8. Check for leaks at all O-rings and flare seats.
Bleeding Brakes with ABS (Using Tech 2)​
You can now use the Tech 2 “Automated Bleed” to purge the ABS modulator completely.
Step 1 — Bench Bleed Master Cylinder​
Clamp master in vise, fill, and use bleed kit to push air out until no bubbles.
Install on truck immediately; plug ports to prevent re-entry of air.
Step 2 — Manual Pre-Bleed​
  1. Fill reservoir with fresh DOT 4.
  2. Have helper pump pedal slowly 3–4×, hold down.
  3. Crack bleeder starting from RR → LR → RF → LF.
  4. Repeat until clear fluid at each corner.
Step 3 — Tech 2 ABS Automated Bleed​
  1. Connect Tech 2.
  2. Navigate:
    Diagnostics → Model Year 2004 → Light Truck → C/K Utility → Powertrain → 5.3L → Chassis → ABS/TCS → Function Tests → Automated Bleed
  3. Follow prompts: pump pedal, open bleeders when instructed.
  4. The Tech 2 will cycle ABS solenoids and motor to purge the modulator.
  5. Keep reservoir full throughout — if it runs dry, start over.
  6. Once complete, perform another manual bleed (RR → LR → RF → LF).
Step 4 — Final Checks​
  • Firm pedal after 2–3 pumps.
  • No hiss / sponge.
  • ABS activation test at low speed — should pulse normally.
  • Recheck PS reservoir; top if low (the HB shares fluid).
✅ Post-Install Checklist​
TaskTarget
PS fluid levelCold = ½ in below full line
Brake fluid levelMAX line
Pedal travelFirm after ½ in take-up
Assist responseImmediate; no lag
Steering noiseNone when turned
LeaksNone under pressure
Tip – Pressure Testing​
If you want to measure your new boost output:
  • Tee in a 0–2,000 psi gauge at the HB pressure line.
  • Under hard brake + steering load, you should see ~1,700 psi peak (vs. ~1,300 stock).
    That’s how you know the HD hydroboost is doing its job.
Woned2004
