Finally got my car sold, yesterday, so, I immediately bought everything I'd had my Amazon cart. Summit was gonna take too long for the same stuff..
KN NextGen intake
J&L AOS (Corsa was actually $20 cheaper at Summit, and in stock!)
Phillips HIDs (stock box of light is cool, but, I NEED flicker, again!)
AVS window.. Things
GDIOMGWTFBBQ cleaner (which I still need to figure out how to do correctly)
I'm a lot of things - a Dog Dad, a Gym Rat, White Collar CryptoBro, Iron Chef.. One thing I'm not, though, is patient. I'm very hashtag Blessed, but, I'll pray in Thanks before I ever ask for Patience . . I know better.
Today, I installed that intake, since it arrived about an hour before I was off work.
Ugh. Supposed to be straightforward, right?
Wrong.
What should have been an hour job turned into three.
How, you ask?
Lemme tell ya, the cone sits in the box, right? It's supposed to sit flush. It wasn't until the second time I pulled it back out, that I inspected the sealing area - it was unevenly . . Cast, I guess? Take pocketknife, start, "clearancing" the hole, to get the filter to sit flush with the box. Test fit, it works. Pull it out, put box back in the chassis. Slide filter in. No Go. Apply hella pressure. Newp. Pull it back out . . Repeat. Was finally able to get the cone in, but, only if I have it in BEFORE it goes in the engine bay. This means there's only the two anterior bolts holding it down because the large end of the filter is blocking the one bolt hole on the opposite side. It'll have to do, for now.
The core support brace comes out, but, the other, larger chassis brace does need to come off the fender, just temporarily, as it impinges on the corner of the airbox. Once I got the box in, obviously, it didn't feel very seated, but, once I applied pressure to it with the chassis brace to bolt that back in, it stiffened up a bit. With everything in place, it doesn't move a whole heck of a lot.
All this and the PCV lines were actually the easiest part. I finally got it to sit correctly, clocked the tube into the filter, tightened down the clamp, got everything all squared away.. Now it sits solid.
Got everything back together, no job is complete without, "Where the fсk did my ten go?!" trying to put the negative terminal back on..
We sat and idled while I cleaned up, no codes (Thank God; the time I had, I was actually expecting that!)
Drove around the block - Meh. Didn't feel faster. Just louder, and I think I lost some low-end grunt.
Went back home, fed the dogs (their dinner was late because of all this) and washed up, decided I'd take the stock parts to storage. Threw 'em in the back, let the Fiancé know I might get stranded (She's away on a work trip, lol) and off I went.
Given a little bit more time, less traffic, I got to playing around with it - I don't recall the speedo skipping numbers, before, but it does, now. While it doesn't FEEL like it's accelerating faster, by the numbers, it appears to be. We'll see. It's certainly loud on acceleration. Sounds alot like the exhaust. If I'm just taking 'er easy, no change in sound, from stock. Shifting does feel a little.. Different. Jerkier? It probably needs more time and milage to learn.
Gas mileage is noticeably improved. I know what I used to burn on this trip, and as I drove, tank estimate went up and the gas gauge didn't move, so, that was actually a plus.
Remember what I said about patience and ordering new bulbs? Three guesses what I'm doing, tomorrow..
If you made it this far, you now realize I'm also verbose.
'night, fellas.
