I lost the set of keys yesterday for the Tahoe that had my Boost Auto key fob along with a house and mailbox key. I went to order a new 2015 style fob (price has gone way up it seems) and saw they now sell the 2020 style for the GMT900 platform only so I ordered the new version. On an unrelated note… bought these 2 Koi to add to my collection. My pond is filling in nicely. The fish are in Hawaii and will be shipped after they don’t eat for 2 weeks, poor guys. View attachment 459289View attachment 459290View attachment 459291
Boost Auto link
Are Koi carp? Be careful of the raccoons--they love to eat fish.
Scrappycrow
Air Force
Alpharetta, Georgia
Boost Auto link
What are the advantages over a stock replacement fob? Being able to program it yourself (if you buy the programmer)? I'm not rough on gear, so the sturdier construction wouldn't be a major draw by itself.
alpha_omega
Michigan
I lost four babies and my oldest butterfly Goldie to a Great Blue Heron this spring. Right after I cleaned the pond. I even had line set up to thwart them off. Since then, I have invested in a “pond tent” and a solar powered motion sensors automatic sprinkler. If it were legal to shoot them, he would already be in the freezer. The dober got close to eating him once already.
As for @Tonyrodz mentioning raccoons, that’s why I keep a large square piece of foam on the pond, along with aiding in adding some shade on the hot days. You can see the scratch marks where they have tried to get there. They like getting wet about as much as a cat does.
Edit: I guess you can’t abbreviate the word raccoons anymore. I didn’t realize that was a thing. Can we call them trash pandas or will that get blocked as well?
alpha_omega
Michigan
Is it just me or does this female end for the (edit) intermediate shaft look a little unsquare? Must have been Friday and someone forgot to QC the finished product. The bad part - this is OEM.
dkad260
Is it just me or does this female end for the lower steering shaft look a little unsquare? Must have been Friday and someone forgot to QC the finished product. The bad part - this is OEM
Another possibility is given the fact they can be a bear to reinstall at times, maybe it was removed at an earlier time and someone tried to turn the wheel a little to get it to seat and it with barely any of the....shaft in the coupler, it could have cracked the end.
alpha_omega
Michigan
It’s brand new, never been used. I’m installing it on a brand new steering rack.
Also, you lost me a little there at the end. What would be cracked? Nothing is broken. The gap is there because I was trying to install it, but I couldn’t get it to seat. That split at the end is supposed to be there. It helps with removal because like you said, they can be a bear not only to install but also when removing.
After pulling it out and filing it down a bit she’s all good.
I guess it's hard to tell by the pic, but the area in the circle looked rough and not uniform so I thought a piece had chipped off in that gap area. It's been awhile since mine was removed so I forgot exactly what it looked like.
I was going to suggest filing it but looks like you got it figured out.
Run4st
Finally got around to doing some needed items. Had to replace fuel lines from filter to tank. Since had to drop tank also replaced fuel pump (kept old one as backup). If this fuel pump goes then I will be cutting the floor and making a little door. While tank was off replaced rusted brake lines (just used OEM line). Paid local shop to do lines ....was not about to do that laying on my back in the front yard. Did AC Delco plugs and wires. Also did the intermediate steering shaft and bushing...laying under dash so might as well do both. Damn my back is getting old.
alpha_omega
Michigan
Gotcha. No, that’s both what the keyed/stepped portion looks like and the shadowing from the lighting. There might be some overspray from copper anti-seize in that area as well, adding to that chipped look.
Nice catch though, I can see now from the photo why it would look that way. I’m looking at it in person scratching my head and wondering: “Did I miss something here?”.
alpha_omega
Michigan
How much of a pain were those fuel lines? I’ve done brake lines, and will never do them again.
Maybe with the right double bubble flair tool and the new style flexible lines it wouldn’t be so bad, but the old hard lines with zero give were a nightmare. The new ones you can damn near bend by hand, whereas the old ones wouldn’t budge using a conduit bender. Then all of a sudden 170° with a hairline crack. Or it would blow out a foot from the location you repaired.
I tried repairing my hard line that feeds into my steel braided brake line on my ds rear caliper(03 Tahoe). Someone used a compression fitting to repair it--it was leaking like a mf'er. Bought a double bubble flaring tool from HF. Very long story short--I bought a length of flexible pre-made hard line from Advance Auto. Was so much easier.
Scrappycrow
Air Force
Alpharetta, Georgia
By "The new ones you can damn near bend by hand," I take it you mean nickel-copper/NiCopp/Cunifer. I started using it for every hard line about five years ago, and it's a pleasure to work with. Easy to fabricate and easy on the tooling.
Before anyone reacts with anything along the lines of "USING COPPER FOR BRAKE LINES IS DANGEROUS!!!," please educate yourself on nickel-copper/NiCopp/Cunifer, which isn't "copper." OEMs such as Volvo have been using the stuff for brake lines since the '70s.
LSCALADE
What brand black housing headlights do you have there? DEPOT from Ebay, they were around 210$. Those seemed to have been bought the most and the reviews were quite ok if I dare say good. Most other housings seem to always complain of bad beam and water intrusion.
How long have you had them? They have been on the car for 3months and have not had the fogging or water injestion issue. I was going to reseal them but was impatient and decided to swap them and see who they look and to my surprise they did not leak.
Any issues with condensation? None at all.
What’s your opinion on the light output of the HID projector compared to OEM headlights?
Original plan was to actually open the new lamps and install a proper HID projector, however I discovered a very nice replica of the HELLA E55 projector that is in the original housings done very well with a clear lens and very sharp cutoff and the hot spot is centered at the cutoff line so they are very OEM like projectors and they are DOT certified and I am not surprised given these are DEPO lamps and they are used as repairs post accidents by certified body shops.
SO I left the projectors alone only thing I did was install new bulbs and ballast on the driver side and down the road I may try LED bulbs but I know they will ruin the beam.
I love the look of the black trimmed housing on the GMT900 Escalade but am so hesitant to go with an aftermarket headlight housing…
They do look nice, I think this is a good set up for decent price to swap old aged lenses and projectors. my old housings will not adjust at all and that was enough reason for me to throw them out of the truck.
Raccoons don’t stand a chance in my backyard with a 110 lb Malamute at the ready. Besides, it’s 4’ deep and if they can’t stand up they can’t do shit. A swimming raccoon is only trying to get to where he can stand up. Also, nearly all my Koi including those new ones are around 18-20” already and growing fast so they might scare the raccoons themselves. The Koi eat anything after all, they might eyeball them. :emotions33:
You can program any of the factory or aftermarket fobs without a programmer for this platform. I personally love the look and feel of the 2015 style that I was using on 3 of my trucks over the stock style for their respectable years (2002 and 2008)and since I have to replace the one I lost, I figured since they came out with the 2020 style, I’d upgrade for a few more bucks. I’m also one of those guys who does a lot of modifications to my vehicles, I never leave them stock.
BadDaddy2003
