Geotrash
Dave
Richmond, VA
Thank you...:)
The only alternative for good tools is; more good tools.. :Big Laugh:
Today I welded a holder for a transmission fix...
I will repair my first 4L60E...
I hope NickTransmissions like Germans...;)
I don't know about the 4L60E, but the 6L80 is based on a German design (ZF), and we know Nick likes those!
89Suburban
Bull in the china shop
SE PA
As an Amazon Associate we earn from qualifying purchases.
j91z28d1
Antique car guys all swear by a 1 to 1 mixture of ATF and acetone to break rusted bolts loose.
The consensus is it works far better than PB Blaster.
Also, the crayon method has good reviews as well.
I feel like I've seen that debunked a few times. I believe the acetone is supposed to make atf super thin and then evaporate.
I tend to agree with that south main auto guy, it's all just to make you feel better. I don't think any of it has actually helped me break a bolt loose, but it does 100% help once you get it to break loose to not gaul up the threads the rest of the way out. but anything thing will help with that. I once had a Isuzu exhaust bolt that was on the edge of snapping off, would only budge a tiny bit either way before locking up. soft metric crap bolt too, tried everything in the cabinet and it didn't help. we had at least 6 different brands haha. in the end hours later I got annoyed, soaked it down with brake cleaner and it moved. had to keep spaying it since it drys so fast.
tried the same brake clean a few times since and never made a difference. something about that one rusty bolt I guess.
nonickatall
Germany
Where did you get your hands on that aligner setup?
@NickTransmissions
That was extreme luck. The system used to be property of my neighbor. We are good friends and help each other often. He bought that system used year's ago, but didn't use it much.
He has a much smaller shop than me, and permanent space problems so he asked me if I want to have the system for free. And he could use it, if he needs to.
So the system came exact in that moment, when I had to replace my tie rods...
Sometimes you need not only a truck, you also need some luck...
Even if it's luck, to own a truck...
:Big Laugh:
nonickatall
Germany
My experience is:
The only things that really works to remove rusted bolts is:
Heat
Impact wrench
Sensitive applied force
Patience
Feeling for the material
Or
Drill
All the oil and Magic Fluids help not very much...
Jdsfx1
Shortened my driveshaft to match my shortened frame. Time will tell if it needs re-balancing. I used 1-1/2 angle tacked to the shaft prior to cutting. This maintains u-joint clocking and helps align for welding. I put another piece of angle over the cut pieces and clamped it for the weld.
Charlie207
LFOD, New Hampshire
Didn't Project Farm test that homebrew mixture in one or more comparisons? It never did that well.
VinceB
