I loosened the upper bolts when I did mine too. Made the job much easier.
For those with autoride struts reading this, remember to hit the electrical connector on top of them with electrical contact cleaner before reassembly (assuming you have them), or you'll get a suspension code. I've seen it happen to a few people here.
I didn't unplug the connector on top I just loosened the 3 nuts and let it dangle
then went and looked up the torque specs and tightened it back up I think it was 34 or 37lbs
Actually, this is helpful, because it'll remind me to remove the swaybar frame mounts, and grease those bushings up. I'm hoping that's the squeaky noise culprit. It's driving me insane with the windows down. Sounds like a high-pitched mouse "eeep eeep" noise.
the sway bar is easy if you have the wheels up and end links loose or off then just do one d bushing, bolt it back up then do the other side. that way your not fighting the weight of the bar very much. I have the hellwigs so there heavier anyway.
Sir_Hiro
Automotive Mad Scientist
That’s because the bags had 45-50 PSI, pretty much at ride height. Aired out, the pinch welds lay on the ground. It has a stock floor body drop, the frame is custom built from 2 x 3 tube steel. No need to channel the body- that would be the easy way and look bad on the interior. ;) :happy107::cool:
I want that look my 77 lol. Low and Slow baby
Charlie207
LFOD, New Hampshire
Welp.... Had it all apart in 25 mins, but the universe has a funny way of slowing you down.
Charlie207
LFOD, New Hampshire
Carbide and cuss words....
Now just trying to find some camber bolts... NAPA website listed just the bolts as in-stock, but the guy on the phone couldn't find them. About to call AutoZone and O'Reilly. For a temporary fix to limp to the store, I found some new control arm bolts from my old Armada to jam in there for the ride to the store and back.
this is part of the reason why I always have 2 vehicles even if one is a pos beater or something that rolls. If I had room I would have 4-5 again, but no parking spots around here.
if one goes down just jump in another...
that bolt didn't look all that rusty, I wonder if someone over torqued it in the past...
Charlie207
LFOD, New Hampshire
Yeah, I used to have two cars for summer/winter, but I've been "blessed" with such reliability out of this Yukon. Stupid bolt.
Geotrash
Dave
Richmond, VA
This is me, in a nutshell. I like having backups.
Bought this hitch cover kit; waiting on automotive touch up to send me the paint I ordered a week and a half ago. Anybody install one of these? I see where to install the bracket but any tips would be appreciated. Better yet, a pic of the bracket mounted would help me position it exactly.
Bought this hitch cover kit; waiting on automotive touch up to send me the paint I ordered a week and a half ago. Anybody install one of these? I see where to install the bracket but any tips would be appreciated. Better yet, a pic of the bracket mounted would help me position it exactly. View attachment 453736
I would give you a picture of mine but I think the Denali bumper cover/pad is different. Mine didn't have the cover and I got rear-ended a little bit and I just claimed that it must have fell off from the accident so I got one for free, painted and everything lol
There’s 2 styles. There’s one that looks like mine and one that looks more squarish like this. There doesn’t seem to be any rhyme or reason, just depends on which bumper you have. Escalade/ Tahoe/ Yukon, the only one for sure is the Esky has the squarish one every time.
There’s 2 styles. There’s one that looks like mine and one that looks more squarish like this. There doesn’t seem to be any rhyme or reason, just depends on which bumper you have. Escalade/ Tahoe/ Yukon, the only one for sure is the Esky has the squarish one every time. View attachment 453743
ya mine is the wider one like this, it just clips on the bumper with twist locks on the bottom
Charlie207
LFOD, New Hampshire
Didnt take any pics last night because my phone was inside, but I made it to NAPA after they called back saying they found a couple camber bolts/nuts, sans plates (mine are still fine).
Limped home, and finished the UCAs, threw in the new outer tie rods, then did a quick/dirty string alignment to get me to the shop for a real alignment in a couple hours. Luckily the shop is less than 10 mins away.
I had picked up some silicone grease at NAPA to slather my swayhbar bushings in, but when I pulled the fronts off they were severely deteriorated.... at under two years old. Im gonna order some new ones, but what the heck... They were Dorman BSK90229PR.
j91z28d1
Alignment done, all good. I hate how the winter roads around here absolutely jack up your vehicles.
my last alignment had way to much toe in.. was feathering my front tires on the outside 2 tread blocks at less than 10k. might want double check with that string if you have time.
I had to take some toe out, left just a tick in, rotated tires and haven't started feathering again.
992dr
Eastern N.C.
Been driving mine and just enjoying that the TC has been locking and unlocking like it should haha
I have been hoarding parts to do the aluminum front end refresh and I found this locally to add the weight reduction theme :)
Anyone ever rebuild a motor? This'll be my first.
ASG-MikeS
