thefrey
- Joined
- Feb 3, 2025
- Posts
- 419
- Reaction score
- 469
Newish to me 2013 Yukon XL Denali with the 6.2. 199k miles. Got it cheap because was neglected and needed lots of love
Oil pressure sending unit was stuck and tripped a CEL and was replaced around 500 miles ago along with fresh full synthetic oil
I’ve been chasing a slight tick in the engine (last owner said they did lifters 10k miles ago, didn’t delete AFM) but it doesn’t seem to be a consistent tick and is very intermittent, so it’s pointing me to oil pressure. The tick doesn’t quite sound like a stuck lifter, an exhaust leak, or a knock.
After the oil pressure sending unit, cruising oil pressure was 40 for 2 weeks and now is dropped to around 24 at 1800rpm and is about 15 at idle hot. AFM activates when the engine is cold but doesn’t when it’s hot. I believe AFM activates from oil pressure.
Assuming there is no stepper motor issues in the gauge cluster, what things could be causing the slightly low oil pressure/tick? Are they generally related (assuming lifters are ok)? Would a new o ring for the oil pickup tube possibly fix the issue? Any help is appreciated. My theory is either o-ring, plunger stuck in oil pump, or pressure relief in oil pan. Just don’t wanna throw the parts cannon at it
