It's got a ghost, also lights on/off when tapped on
Huh, discovered there are 2 different versions luckily the buttons can be swapped otherwise won't fit the panel because of the gap in the middle. Was just messing around in the junkyard and got this one for free, they gave it to me, lights work I can return the one I ordered View attachment 448228
Here's the actual report from the inspection:
I kinda knew the emission stuff wouldn't pass, since I recently did the rear O2 sensors, and apparently haven't driven enough miles/hours to complete the internal readiness tests. The TPMS is dumb, because my winter wheels/tires don't have the sensors. There should be a way to turn that alarm off in the Tech2, yeah??? And I've had 6qts of fresh synthetic and a new filter waiting for the oil change for a while. I think they just looked at the oil change monitor percentage (that I never reset). It's only been 4500-5000 miles since the last change.
I ordered two AC Delco balljoints from Scamazon (I know... I don't care) because they'll get here Saturday, so I have time to rent the tool and maybe buy a pickle fork.
For others who may have implemented something similar; just found this product which claims a 10 year battery life for the AirTags.
10-Year Battery™
Over 14x more battery capacity than AirTag's CR2032 coin cell. Uses two AA batteries (Not Included). We recommend Energizer Ultimate Lithium for longest life (25yr life, no leaking, flat voltage). We do not recommend alkaline batteries. Easy assembly: Discard AirTag's battery and door, place on...www.elevationlab.com
While I haven't had to replace the battery in my 2500 yet I've ordered a set and plan to hide the tag a bit deeper in the vehicle. The key is to get the AirTag as high as possible without the possibility of it being found.
Cannot recalibrate, have to replace it with new. Must use inop rod in steering wheel/column and not remove pin in sensor until latter part of installation.I wonder if this tactic might work to allow me to finally recalibrate the steering angle sensor on my '07. I installed a new one a few years ago but messed it up when the wheel moved ever so slightly before turning the key on, and now as soon as I turn the wheel the first time after starting, I get the Stabilitrak/TC off warning. I don't even notice it any more, but I would like to fix it without replacing the thing, but it's not an option on the GMT900 menus. Going to play around a bit and see.
You didn't tell me!that's been confirmed a long time ago.
What LED bulb is that for your courtesy light?
Airtags will use any other Apple device and perform a BT connection to the other device to go out to the internet to report location.from what I read, always put 2 air tags in. one that's fairly easy to find. because their phones will go off if one is around following you that's not yours. and they will tear stuff up till they find one.
but once they find it and silence the notification on their phone. the 2nd one will still be there.
location doesn't really matter. it doesn't use cell service. it Bluetooths to the phone of the guys that took it without them knowing it.
I must have done mine just right, because it worked perfectly, right from the get go when I replaced mine.Cannot recalibrate, have to replace it with new. Must use inop rod in steering wheel/column and not remove pin in sensor until latter part of installation.
You didn't tell me!
They will talk to an iPad, Apple Watch, etc. that has either a cell connection or a WiFi connection.
I don't have any Apple devices, but the installing 2 Airtags is a good idea.
It's too bad Apple doesn't have a way to limit who can see the Airtag ping so thieves wouldn't be able to see the ping following them around.
If you don't touch the steering wheel, you're good. They made that pin for guys like me!I must have done mine just right, because it worked perfectly, right from the get go when I replaced mine.
Solved the Stabilitrak error as soon as the steering wheel was moved.
Man no idea to be honest I bought some of these like several years ago, these are blue color that I use for the puddle lights. I know I got them off of eBay but eBay only keeps a record for 2 years. I can recommend the Auxito bulbs though and only from a genuine auxito dealer, there are fakes out thereWhat LED bulb is that for your courtesy light?
I need to replace mine, the cheap ones I bought failed rather quickly and I want to put something decent in there.
I've used Auxito LED bulbs in headlamps and other places and they have always performed well.Man no idea to be honest I bought some of these like several years ago, these are blue color that I use for the puddle lights. I know I got them off of eBay but eBay only keeps a record for 2 years. I can recommend the Auxito bulbs though and only from a genuine auxito dealer, there are fakes out there
this guy has genuine auxito, the bulbs in the puddle lights are T10
Security Measure | eBay
www.ebay.com
found ebay purchase history going back to 2020 but I bought those bulbs before then, they may even be from 10 years agoI've used Auxito LED bulbs in headlamps and other places and they have always performed well.
Have a set of headlamps in one car that are still doing well after about 4 years.
Thanks for the heads up.
when I find something that works I usually buy a couple sets and put then in the tool box, 1. because if I need one I have one on hand already and 2 in case the seller disappears or they are no longer made, etcdid they fail it because the o2 heater or both. I thought I read they would still pass it if one of the i/m was incomplete but not failed.
Can you show us or tell us how you did that?
In NJ all monitors need to show ready. Even one not ready you'll fail inspection.I don't know the relevant NH-specific laws regarding readiness tests, and the paperwork just stated that the emissions test failed (but I honestly didn't pay that much attention to it). I don't think NH is similar to other states that may allow one of the tests to be non-ready, and still pass overall.
This is the state website: https://www.nhinspect.com/what-to-expect/
If the monitors don't reset in a couple days, I'll probably reinstall the old O2 sensors, and see if they work.
