Bad mpg?
Status
Not open for further replies.
Antonm
Lets look at this drastic difference you've called out here. Which is an efficiency difference, thermal efficiency in this case. Which I've said all along the two engines efficiencies' are very similar,,, similar enough to be negligible and considered the same.
Looking at the scales on both axis, not a lot difference between 5.3 and 6.2, but since I'm sitting in front of an internet connected computer (its a work day after all) lets quantity that particular efficiency difference I say is negligible with actual hard numbers shall we.
First lets digitize that graph using this open source (available on the internet) program .
That'll allow us to pull actual numbers off the graph without being accused of interpretation error. So that give us the below points we can throw into excel and re-create the curve.
After a little copy/ paste and graphing in excel, we get this, and we can extrapolate values for 5.3 and 6.2 L from it pretty accurately.
Y axis value of 5.3L = 311
Y axis value of 6.2L = 294
For delta of 17
But those numbers are in gm/KW-hr,,,,so lets do some unit conversions over to freedom units.
Each gallon of gasoline has 3217 grams, so that comes out to 0.0052 gals/ kw-hr
128oz/ gal so, 0.67oz/ kw -hr,,,, but who likes talking in terms of KW, so with 1.341 hp /KW that comes out to a whopping 0.504 oz/ hp-hr.
A tablespoon contains 0.5oz ,,,, so a tablespoon is the BSFC delta between 5.3 and 6.2L in hp-hr.
So lets take this a step further because hp-hr is kind of a strange term that's not really relatable.
Lets say driving down the road at 70 mph it takes 200 hp to keep the car moving (which is within the realm of reason for these heavy bricks) and you do that for one hour. So that means the delta in fuel usage for that hour is 100oz (0.5oz * 200hp for one hour). So in that hour/ 70 miles you used an additional .78 gallons of fuel, so your fuel consumption went up by 0.011 mpg. Better get Greta on the phone, you've fixed all the worlds issues.
Considering the fuel consumption of these engines in general, I'm calling that the same.
So again, burn the same amount of fuel (at the same afr) in two engines with the same efficiencies , get the same amount of power.
Antonm
There is no abandoning the argument, here.
The 5.3 can get to same power as 6.2 at same afr (within reason) with increase engine speed.
You made both of the statements above in one post, yet you say that you also "stand behind" your statement that started this whole argument (see below).
Can't have is both ways my man, both can't be true.
Are you now pivoting to efficiency differences (from the previous afr differences) between the two engines? Because sure there are differences there (talking efficiencies now) in an absolute sense (like if I were to pour a gallon of pure distilled water in the ocean, technically the ocean's salinity/ salt concentration would change ,,, not by enough to make any practical difference, but it would change). Which the about the magnitude of efficiency differences between the same generation 5.3's and 6.2s at part throttle.
blanchard7684
Senior Member
For delta of 17
I posted the trend for reference that displacement decreases BSFC.
(Credit due...I'm actually impressed with the graphing and it adds to the discussion. Well done.)
To get a real look at BSFC for these two engines you have to have the specific engine contour plot of mean effective pressure vs engine speed and plot it over incremental power levels. The contours are different levels of BSFC.
It would look something like this:
I'm not claiming a huge difference.
For the same AFR, same rpm, same ve, the power levels will be different based on displacement alone.
For low power demand, will rpm, afr, and ve be close? yep. For high power demand, 5.3 can't get there. For mid-range power the 5.3 will need to increase engine speed or richen fuel mixture--to the point where it's fuel consumption per mile is at a deficit to 6.2.
blanchard7684
Senior Member
if all other things are equal, then according to the power equation referenced, there is not a mathematical path to same power with a displacement difference between 5.3 and 6.2, if the afr is the same.
If other variables are opened up for change, then the 5.3 absolutely can make same power at same afr. The same power equation says so.
Antonm
Splitting hairs again, since both the engines being discussed hear have the exact same stroke length (3.62 inches) , piston speed is identical for a given RPM.
And since they're only 0.9 L worth of displacement different in diameter (little over 1/4 inch bore size) their contour plots will look/ be very similar too because their rotational speed isn't that much different at a given power level.
Pressureangle
The part you missed is that in this scenario neither engine is operating at WOT and minimum manifold vacuum. The only difference between the two at the same AF ratio and RPM is the manifold vacuum and mean cylinder pressure.
Antonm
You do realize that if you put the same quantity of air in two different volume cylinders, the pressures will be different right?
For a given set amount of air ,,,, say that amount of air needed to perfectly burn a given amount of fuel at stoichiometric ratio, if you put that amount of air in a smaller engine then;
But if you take that same amount of air (the amount needed to burn a given amount of fuel at stochiometric), and put it in a larger engine, then you get;
Maybe I should have mentioned this earlier, but I just kinda assumed this was a common sense thing.
So burning the same amount of fuel, at the same afr (which requires the same amount of air) in two different displacements engines makes the same power ( assuming the engine efficiencies are the same of course).
That lecture you keep referring to even alludes to that later on when talking about ways to raise power, see Pressure (adding boost) at BDC statement below.
I think that maybe you've not be seeing the forest for the trees and focusing on just the equation as symbols, and not what the equation is actually doing/ telling you. Which happens even in the adult / professional world every now and then.
blanchard7684
Senior Member
Points for creativity. It made me think.
However...
The pressure at bottom dead center is the result of the pressure drop from atmospheric pressure in intake housing, across the throttle blade, through the intake runner, through intake ports, and across the intake valve.
I'm assuming the pressure drop has been the same for the sake of discussion.
These intake systems are acoustically tuned and not just for WOT performance. The 6.2 has 2.12 intake and 87 mm throttle body. The 5.3 has 1.9 intake valve and 80 mm throttle body. Not sure about the intake manifold volume between the two engines. They have the same stroke so GM likely made the intakes designed to have max pressure pulse at same crank angle. So in effect they should be the same at BDC.
So I can't get into the idea that the cylinder pressure at BDC is so much different that it takes out the effect of displacement.
Antonm
However...
The pressure at BDC is a result how ever many cubic feet of air you have trapped in a given size cylinder.
How that air got there, via what size throttle body, or intake valve , naturally aspirated or forced, is irrelevant to the the pressure it'll create once its in there.
Simply put, if you add "X" amount of cubic feet off air in a set volume, you'll get "Y" amount of pressure every time. Increase that volume, the pressure will go down for that same cubic feet of air (and the reverse is also true).
And to burn a given amount of fuel at the same ratio, you need the same cubic feet of air, not the same pressure, the same volume/ the same cubic feet.
Sorry you can't wrap you head around the idea. I can't wrap my head around the idea that there are women making millions of dollars selling pictures of their feet on the internet, but that doesn't mean it isn't true, or that it isn't happening, just means I can't understand it. It would appear the same goes for you understanding this issue I suppose.
blanchard7684
Senior Member
I had a whole reply typed out but it got timed out somehow...
I appreciate the work you put into the graph and the calculation.
The trend was for reference.
I have done contour mapping before with an engine that had 0.8L difference in displacement and there were a few spots on the map where BSFC was different (with the larger displacement showing a lower bsfc). I can't post IP so all I have is an open source plot showing effect of displacement as well as another plot showing effect of rpm and CR on BSFC (which favors the 6.2 in this discussion).
As far as power vs speed, the 6.2 does make quite a bit more torque at lower rpm ranges than 5.3. Point being I think there is a larger than "a hair's" difference going on.
blanchard7684
Senior Member
The pressure at BDC is a result how every many cubic feet of air you have trapped in a given size cylinder.
The feet thing is hilarious.
Bolded part isn't true here is why:
The pressure starts at a maximum of atmospheric and decreases from there.
At WOT you might get back to 90% VE. (Racing applications can get above 100% VE.) This is from acoustic tuning. You are tuning the pressure pulsations to coincide with the desired crank angle or crank position.
The pressure at BDC is highly dependent on pressure drops along the flow path. This is true for any system flowing a gas or liquid.
If you have a pipe of a gas with a pressure drop across it due to a valve, pressure on one side will be higher than the other side and this drop is dependent on the flow characteristics of the valve.
The air flow into an engine is no different.
Antonm
However...
See post #161 above, the difference came out to 0.011 mpg (at sustained 200hp usage) based off the difference in BSFC. Note, that is 0.011 mpg.
There is not a significant difference in getting 18.02 mpg compared to 18.01 mpg ( that difference would be 0.055%, seems like a hair to me.)
blanchard7684
Senior Member
The trend showed the effect of displacement on BSFC.
CR is another variable that improves BSFC.
And engine speed is another.
You combine these into a contour plot.
The bullet points on this slide elude to the other ways BSFC is affected.
Antonm
Did you intentionally miss the part that says " Once its in there"? or are you just blindly leaving that part out on purpose?
Yes all those factors you mentioned affect how much air may get in the cylinder, but once you trap an given volume/ cubic feet of air, how that air got there makes no difference on the pressure it'll create once trapped.
This isn't a hard concept to grasp, there is even a real simple equation for it;
Pressure at point one (P1) times(x) volume at point 1 (V1) = Pressure at point 2 (P2) times (x) volume at point 2 (P2) or shorthand of P1 * V1 = P2 * V2.
Please tell me you've heard of this very basic equation before, its like high school, maybe even middle school, level.
And what does this basic equation tell you if you trap the same amount of air in two different size cylinders?
And most (if not all) automotive engineers use psia when referring to air pressure in naturally aspirated engines, makes the calculations easier when you don't have to cross zero all the time or use negative values. There is even a sensor called the MAP sensor, why don't you goggle up what the letters M.A.P. stand for in that sensor real quick. Maybe then you'll understand how easy calculations can be even when using pressure below atmospheric.
Antonm
Are we back to arguing efficiencies now?
You jump around a lot as to what point your trying to make, and what parameter you think is doing what, its hard to keep up with what crazy/ misguided/ twisted thing you're trying to say is doing what, reminds me of when I kids where real little kinda.
Are you done with afr and moving over to the small differences in efficiencies now (like that HUGE difference in BSFC)???
blanchard7684
Senior Member
The induction system will change the quantity of air in cylinder. There is pressure drop and flow restriction.
Saying it is the same isn't correct.
Post 171 covers this as well.
blanchard7684
Senior Member
You jump around a lot as to what point your trying to make, and what parameter you think is doing what, its hard to keep up with what crazy/ misguided/ twisted thing you're trying to say is doing what, reminds me when I kids where real little kinda.
Nope I cautioning on using that trend for anything more than explaining how displacement affects bsfc.
It isn't an actual contour map for 5.3 or 6.2.
Antonm
Not true, we (the operators/ drivers/ whoever is pressing the go pedal) determines how much air is drawn in. And if we want to make X amount of power, we draw in the air required to make that power
Lets get some basic statements we can agree on, read the following at tell me if you agree or not.
1.) the equation P1 *V1 = P2 * V2 is real/ accurate.
2.) to burn a given amount of fuel at stoichiometric ratio its takes a given cubic feet of air.
These are very, very basic concepts, do you acknowledge them?
Antonm
The contour maps for two engines that are virtually identical except for 1/4 inch of bore diameter are very, very similar. The differences are on the same (and insignificant) order of magnitude already shown.
Side note, its getting late in the day for me, time to go home/ get away from the computer,,, think real hard overnight and I'll check back in the morning to see what wonders you've discovered.
blanchard7684
Senior Member
When the throttle is actuated it is changing the effective flow coefficient through the entire induction system. It is the main limiting pressure drop, but not all of it.
Again there is pressure restriction from the intake box, throttle, intake manifold, intake runner, and intake valve.
The mass of air will be different, the volume will be different, and the volume inside the cylinder will be different.
Flow through orifice more accurately models flow through throttle body at part throttle. Flow through venturi would be more accurate model for flow at wot.
Your original comment about an "ideal quantity" (mass or volume...you didn't specify) of air raising pressure in a 5.3 cylinder vs dropping pressure in 6.2, that would/could impact the power equation, is not an accurate or reasonable description of what is going on.
1) if mass is same. Boyle is constant mass. The mass flow rate is determined by the throttle, not conditions at bottom dead center. This is bernoulli, not gas laws.
Alternatively, if you are saying V1 is 5.3 and V2 is 6.2 then the error is even more severe.
If I take 5.3 L at a specified pressure , it will also have a specific mass.
Then if I put this into a 6.2 L container, the pressure will decrease by Boyle’s law.
All this does is prove Boyle’s law, it doesn’t prove your original point about pressure at BDC being higher in 5.3.
In fact all this does, in the inverse, is prove how forced induction works.
If you cram 6.2L into 5.3, you make more power than the 5.3 would at atmospheric conditions.
The reason why this exercise is not applicable is because the mass flow is different between the two engines.
This stems again from how the induction system is configured.
Just think: an 80 mm throttle, 1.9 intake valves, with 5.3L pulling air through them will move less air mass than a 6.2 L engine with 87 mm throttle and 2.16 intake valves.
5.3 has smaller intake runners than 6.2, to go along with this...
2) it takes a given mass of air. Remember you can get stiochiometric balance in any size cylinder, with different masses of fuel and air, which create different levels of power when combusted, at same afr.
Status
CrackerJack135
