Bad mpg?
Status
Not open for further replies.
onyx24
Just picked up a 2024 Yukon SLT 5.3L RWD and driving back from Florida to North Carolina with only a single stop I'm getting 17.5mpg.
Kept it in adaptive cruise control for 95% of trip. Road thru the night so no traffic either.
Is this to be expected or lower than normal?
B-train
Brand new vehicles typically run richer for a predetermined number of miles to aid in the break-in process. There are MANY components that are all finding their groove so to say, give it until 5k and see where you're at.
Also, cruise control will never give as good MPG as a well trained right foot in my experience over many years and miles of driving long distances.
JayceeP
Doesn’t seem that bad for a brand new vehicle that isn’t broken in running at 79mph with winter gas I assume. It is a V8 after all.
Also not sure if you reset this trip calculator after you left the dealer lot or is some of the pre-sale idling, shipping, lot driving etc baked into this number.
Stbentoak
The difference between 60 MPH and 80 MPH is night and day too, also. I want the mileage I get at 60, but Real life is I end up doing 85 and even with the Duramax I'm at about 27MPG. At 60 I'm easily in the 30's.....
tom3
Wow. That's about what these machines got 20 years ago.
As @B-train stated above, I'm sure that you will get better mileage after the truck and all of its systems break in. My 2007 Yukon XL Denali with the 6.2 gets 14 - 16 mpg on the highway at 75 mph.
Antonm
Physics is kinda a *****, and it says to move an "X" amount of mass at a given velocity, it takes a "Y" amount of energy to do so.
Vehicles have gotten heavier thanks to all the mandated safety stuff , and engine efficiency (the only thing that could possibility give better fuel milage) is being help back by the mandated emissions control equipment.
Just as an example, according to google, the curb weight of a base 2001 Tahoe was 4828 lbs, the curb weight of a base 2024 Tahoe is 5611 lbs.
Interesting side note for perspective, the massive 1972 Suburban (in 2WD) was 5200 lbs curb weight, so a 2024 base Tahoe (also 2WD) is 400 pounds heavier than a 1972 Suburban.
Not a big surprise that fuel milage isn't going up, and in some cases actually going down.
jerry455
My 2021 6.2 Suburban High Country 4wd is 5,360 lbs. I weighed it last time I went to the scrap yard. Currently, around town and 7* degrees this morning, I am getting 12 mpg. I have been remote starting it more lately for my wife. I can get 18-20 on the highway.
Coming out of Florida you are going up all the time with few hills to drop down on and coast. The engine is almost constantly under a load and climbing in elevation.
The motor just needs to get broken in and she'll loosen up and deliver better mpgs.
Antonm
How long does this “ loosen up” take? Ours has 17k miles on it now and still gets about that same mileage, sometimes even worse.
I reset the #1 trip odometer (which also has a fuel economy attached) every time I get gas and leave the #2 trip odometer alone/ never reset it. So in theory, I should have short term (each fuel tank) and a long term fuel economy averages, both numbers are pretty similar , and pretty close to the OP number.
JCSFPD
I have a 2024 XL 4x4 5.3L with just over 8,000 miles. Florida to Southern Illinois driving 75-85 mph I averaged just over 20 mpg on a round trip. My mileage improved at around 5,000 miles. It loves traveling at a constant speed. Adaptive cruise keeps changing the speed depending on traffic. I changed to the old style cruise setting and my mileage improved. It also doesn’t make my wife car sick with the drastic speed changes.
JCSFPD
My best 50 mile mpg was 27 mpg traveling at 45 miles per hour. Not by choice road construction on a different trip. That was 2 hours of my life that I won’t get back. Flat road, no wind, traveling almost bumper to bumper.
JCSFPD
I have had an 84, 96, 09, 15, and now a 2024. All purchased new and with the exception of the 2024 they all hit 150,000 before I traded. The 2015 and 2024 had the best mpg by far. Better than I ever expected. The 1984 was good for at best 16 mpg at 65 mph on the interstate. 12 when I towed my boat.
vcode
Yep, all that tech and the mileage actually got worse with the latest Gen (except diesel). Not that you buy one for the mpg's.....
Some of this is computer controlled, the rest is mechanical. I had a new GM minivan that got terrible mileage until she hit the magic number of 9,000 miles. After that, she delivered exceptional performance and gas mileage for what it was.
They basically used the same engines as the K2s and these are much larger vehicles and heavier too. I didn't expect them to be more efficient than the K2s.
When a T1 pulls up next to my old 900, their hoods tower over mine and the cab seems to be a few inches higher. They also run larger diameter tires.
Status
johnsonwillie199
