Bad mpg?
Status
Not open for further replies.
blanchard7684
Senior Member
Yeap, just like mentioned above, the 5.3 might need 30% throttle to achieve the same power the 6.2 does at 20% throttle.
So for all use cases that don't call for more than 355hp (the amount the 5.3 makes), the 5.3 will have the throttle open slight more than a 6.2 making the same power.
Once the 5.3 hits wide open throttle, its done, can't draw in any more air, so injecting more fuel wouldn't do anything to make more HP. Whereas the 6.2 can draw in more air thanks to its larger displacement, so it can inject and burn more fuel, making more hp.
Yes the difference in throttle position is precisely related to ve.
The ve is not constant until wot.
This is why timing maps are dependent on rpm and load as well.
As the load increases, ve goes up because more air is entering the cylinder. To keep the power level the same more fuel is added but the ratio does not necessarily default to 14.7.
If you have been to any dyno or even seen one on media you’d know that the afr isn’t just either 14.7 or 12.8.
BacDoc
Vero Beach Florida
As far as the OP and mileage, I think that your mpgs are pretty good going 79 mph. My 2024 Tahoe has the 6.2l and gets similar mpg going 78-80mph. Here in Florida on flat roads and highway speed limit is 70 mph traffic is usually doing mid 70’s mph so that’s what I’m usually driving on the highway. Some of my routes are 50 mph speed limits and on these roads with cruise set at 55 mph my Tahoe usually gets mid 20’s mpg. This is on flat smooth roads. Not bad for the big V8 with 420hp.
In the mid 90’s I bought a Chevy van with the smaller V8 as I was concerned about fuel economy. That smaller V8 only got 16/17 mpg on highway and close to 12 mpg in city. Always felt underpowered when driving although it towed well with no problems. I put over a hundred K miles on that with no problems but the next Chevy van I bought in 2004 had the 6.0l V8, much better driving experience and I was getting consistent 18 mpg going 75-80 on highway. I was surprised at how the bigger more powerful engine was slightly better mpg and a lot better driving overall.
Now I’m not concerned at all with fuel economy and loving the power, sound and performance of the 6.2l. If you drive aggressively and have fun the fuel economy suffers but it’s worth it lol!
My conclusion is the newer GM bigger V8 can get similar mpg as the smaller V8 and both V8’s can get similar to better mpg than newer turbo charged 6 cylinder engines offered in the newer trucks by other manufacturers like Toyota and Ford.
If your main concern in buying a new truck is fuel economy then the desiel is the best option. Or god forbid buy a friggen Prius
Antonm
Do you know what an air fuel ratio is?
Do you know that they vary depending on power demand?
You have a really really hard time with this.
Your response is amusing and immature.
Which reflects your knowledge of this subject.
LOL, you're freaking clueless, trying to argue points with gross conceptual errors on your part.
Everything we've talked about (at least so far) has been pretty basic stuff ,,, and you've gotten most of it wrong.
Antonm
The air fuel ratio "defaults" to whatever the ECM tells it to.
At light throttle, it doesn't go into enrichment, it stays at, or as near as it can, to Stoichiometric. Becsue the 02 sensors tell the ECM how far it is off, and the ECM adjusts injector pulse width to get AFR back to wherever the tuner (in this case the GM tuners, the guys that will do anything for 0.01mpg to help their CAFE numbers), tells it to.
Antonm
Only been to the chassis dyno maybe 30-40 times, but I have had cars (multiple cars actually) with aftermarket afr gauges in them that I keep an eye on while driving.
And while lean is mean, you always error on the side of rich for safety. What the 02 sensor sees is an average off all cylinders (or an average of all cylinders on that bank for a V configuration engine). So if you're seeing 14.1 at wide open throttle on the gauge, you can bet your left nut that one of the cylinders on that back is running in the 15s, and that can get expensive real quick.
So targeting a 13.0 afr is generally good for both horsepower and for cylinder to cylinder distribution.
The fancy engine dyno guys have headers with lambda sensors in every primary tube, so they get to see just how crappy whatever intake manifold they're testing is at cylinder to cylinder distribution . Some of the more serious drag and drive guys will have headers with eight lambda sensors in them too.
blanchard7684
Senior Member
A dismissive post with ad hominem is usually a good indicator of weakness.
Slow clap.
blanchard7684
Senior Member
Ok since I’m so clueless you tell me:
How is it the 6.2 can get nearly identical mileage as the 5.3 in the same suv with same gear and same mass?
Since your knowledge is so vast and impressive it should be easy.
I have offered a plausible explanation with facts and solid theoretical basis.
Your turn…
blanchard7684
Senior Member
How exactly do you know this?
Do you have an afr vs hp ( or throttle position)chart you can share?
Fuel tables in the ecm aren’t just stoichiometric or full enrichment.
Antonm
Yeap, you're clueless , but at least you had the good sense to go back and edit this little gem out out of your original post that contained it.
Antonm
Easy, because they're moving the same mass at the same rate, and therefore using the same amount of energy,,, maybe go back and review , because we've been over this before.
Antonm
Your turn…
lol, no you've offered clueless explanations based off your own gross conceptual errors in understanding.
You started off by trolling another member with your smart aleck comments of "how does an 02 sensor force an air fuel ratio" bit, then when he (or she maybe, their screenname has "Mark" in it, so I assume they're a "he") took the time to actually respond, you just kept at it even though you don't actually know a damn thing (like a lot of internet trolls actually)
Antonm
Why don't you post your tables that prove it doesn't there Kemosabe.
Antonm
Slow clap.
Claiming a moral victory when the facts of the subject / topic are not in your favor and prove you wrong,,, where have I seen this tactic before,,, are you a politician?
Let me re-phrase your statement above into plain English "I'm wrong, but he's mean, so that makes me right by default ,,,slow clap"
And I bet you also wonder why I think you're clueless too.
blanchard7684
Senior Member
The facts are not in your favor here.
You keep claiming but you are wrong.
I’ve explained why.
Sorry this isn’t a return policy for range disabler.
blanchard7684
Senior Member
Yep that is right and you jumped into a discussion you don’t have the shoes for
Keep hitting up Wikipedia for your info
blanchard7684
Senior Member
Ehhhhhh!
I never said “ same rate”. Way to slip that straw man in.
I was talking about part throttle… all else being equal.
Again… explain this phenomenon with facts, theory, or experimental proof or just take the L ( again) and move on.
blanchard7684
Senior Member
RIIIGHT
You typed out an complete sentence of shear stupidly, they erased it and it was an editing accident.
Your are a Politician aren't you, or at least you lie like like one.
I stand by the statement and erased it on accident .
Ohh you caught me.
Refute that statement then if it is so stupid. Should be easy for a genius like you.
Status
JasonW4141
