Oh man, I WAS selecting the C option, thought "C" was for Chevy!
Welp, that makes sense now!
Thanks Fless!! I would have lived my whole life not knowing...
Ha! Now you're on the right "path!"
Found a company that does TCCM programming...
GM TCCM Transfer Case Control Module Programming — Ewalt's Auto Tuning
This listing is for a transfer case control module (TCCM) that is programmed/flashed for your vehicle with the newest updates from GM using your VIN to match your vehicle. After you purchase the TCCM you will need to provide us with your VIN so we can program it before we ship it to you. The followiwww.ewaltsautotuning.com
ACDelco lists 24261367 covering the NP0, NQF and NQH transfer cases.One thing I was thinking about, regarding the fact that RA does not list a TCCM for single speed t-case: I wonder if the 2-speed one covers both single and 2-speed? I noticed that my original TCCM P/N is listed in the long list of OEM TCCMs it replaces.
Looking at the cardone brand on rockauto, it says "vehicle specific programming required ON the vehicle."
While not cheap, a new Dorman module looks to be $120 after you return core..
I'm thinking not a whole lot more than having a dealer reprogram.
(I'd pay that to avoid going to the dealer!)
Return it if it doesn't work. Send the core in if it does work.
(unless the Dorman requires programming too, hopefully they bypassed the VIN programming..)
Just logged into ACDelco TDS and got big messages about using counterfeit clones (J2534) and a warning that doing so would get one locked out.Hmmm, interesting. Since they all use the same module now, it would seem as if I should be able to find someone that could reprogram my original 24261367 to work with the 2-speed. I will look into that further if the Dorman unit I just bought doesn't solve my issue.
there must be some ***** ones out there my clone mdi updated with the bosch software multiple times and never have had a issueJust logged into ACDelco TDS and got big messages about using counterfeit clones (J2534) and a warning that doing so would get one locked out.
Anyhow, I plugged in my '13s VIN and saw a menu description for programming all three transfer cases and then part numbers for what I believe were the two 2-speed variants.
Ideally, I'd like to get the VIN of a truck with the MP3010 and see what programming options are available to it.Awesome! But since they show part numbers for the 2 speed xfer module, possible original 1 speed modules can't be reprogrammed to 2?
But angry because they gotta screw with us little guys trying to program our own modules they made this stupid way..
I'm pleased to report back that @mikez71 suggestion of trying out a new Dorman TCCM worked! New module installed, did the learn procedure, and everything's working - all T-case modes AND REMOTE START!!! Thanks to Mike and everyone else for the help. Sorry this was such a wild goose chase.
We may not ever know the whole explanation as to why the module worked fine for its function, but prevented remote start. There is one small possibility.... the Dorman module had a sticker over the connector ports saying to "four- pin connector must be connected last to avoid communication errors." (Four-wire connector is the one that supplies power to the module) I did not know that rule when I did the t-case conversion, so it's possible I toasted a circuit or something inside the module.
ditto I sub'd to it from the get go, even digging around trying to help out learned some new stuffthat's awesome it worked.
the wild goose chase is a good thing, I learned some stuff from this thread and I'm sure others will too.
OK, I give, how the heck do you change the thread title? i know I've seen many do that, and I think I've even done it myself, but now I'm not seeing the button or link to "edit thread"I learned alot too! Let's go TYF!!!
Only threw the dorman suggestion out there because I was out of ideas..
It may not have been caused by the '4 pin connector' since you had no communication errors.
Super glad you have it squared away.. You know what to do now.. (SOLVED!)
I believe the option to make changes to the title "times out" you could ask @Fless to make a change, admins have the option to editOK, I give, how the heck do you change the thread title? i know I've seen many do that, and I think I've even done it myself, but now I'm not seeing the button or link to "edit thread"
