2010 Suburban AWD or 4WD, Confusion ?
kirkdc
Currently interested in buying a 2010 Suburban but questioning the 4 WD set up in this one. See posted pic, this is what the dash looks like showing 2 hi - auto - and 4 hi. I've seen others with a selector knob showing 2hi - auto- 4hi and 4 lo.
Whats the difference? I know in the pic there is no 4 low selection, that's apparent - but when it's in 4hi mode is it TRUE 4 WD? Or some type of limited slip/AWD set up which IMO is not a better set up for ice and snow. I've googled the heck out of this topic and come up empty. I live up in the CO Rockies where I need a solid 4x4 system and don't want any rinky d ink AWD/hybrid set ups that don't fully engage all 4 and/or work on a limited slip some basis of sorts. I am almost assuming that this vehicle has possibly some rinky-din k 4x4...or maybe I'm totally wrong and that when its in 4hi the front and rear is always engaged. And the only difference is that it has no 4 low. Any help is super-appreciated.
K
kirkdc
In viewing other surburbans/yukons for sale I've seen this type of selector knob for the 4x4. This is why I'm stumped. It's def' got to be a different 4x4 set up.
K
kirkdc
That simply a single speed transfer case. It is true 4WD. You just don’t get the 4 LO option.
Oh wow that's a relief as I really like the rig. Are you 100% sure? :) just checking...my apologies.
One is a single speed transfer case
One is a 2-speed transfer case
Auto- is 4wheel drive on demand when wheels slip is detected
Only the Yukon Denali/escalades generally have AWD
In all cases the front is a open diff
Most have the G80 rear end which is a automatic locker at speed, I believe around 15mph is when it locks if a wheel slips
K
kirkdc
Ok, that helps and that's where I was getting confused....seeing Denali's, Escalades with AWD lisitngs. Plus I never knew there was a single speed t case that had no 4 low. I'm a 66 year old geezer and would be happy with a 4x4 manual shift lever and 2 hi, 4 low and high and a neutral.
Speaking of Neutral. Does this 2010 Suburban have an application to be the t-case in neutral?
It's in neutral when shifted to neutral, are you asking about this for when it would be towed? I believe that requires the driveshaft to be disconnected
GMCChevy
The 2 speed transfer cases can be shifted into neutral to totally disengage everything. I don't think the single speed ones can.
The singles speed transfer case, MP3010, was generally paired with 3.08 gears. 2010 was the first year of introduction of this transfer case and gear combination.
The 3.42 geared trucks were usually paired with the MP3023, 2-speed transfer case.
j91z28d1
is one any better in the snow than another?
I avoid the snow at all costs but do you need 4lo for snow? I alway pictured that being for low speed rock crawling. high traction low speed grunt. snow being mostly a lack of traction aren't you mostly relying on the stability control/abs to find traction?
wjburken
Eastern Iowa
I have been in some really deep snow and have never needed 4LO.
The need for 4lo is extremely rare, like if you were stuck already, otherwise it serves almost no use.
Unless your intention is to purposely go to some sketchy places often then your going to want to have additional means of extraction anyways. For normal driving it's unlikely that you would ever need it
strutaeng
Dallas, Texas
4Lo is basically just more torque multiplication advantage due to super low gearing. So basically if you get stuck as mentioned and wheels aren't spinning somehow.
I think top speed is like 20 MPH at engine redline or something like that. So yeah, usually not needed unless you have to.
j91z28d1
so I'd guess not something you use just driving thru snowy roads?
so looking at my sector. according to the owners manual. my t case will go into neutral for being towed behind a trailer. so it's definitely more of a old school 4x4 t case the op might be looking for. if you look you can see where the N would light up when in neutral.
I don't know what trucks they would have put this in thou. it might be a one off thing.
Having the option is nice. Most trucks equipped with the single speed transfer case have 3.08 highway gears. I learned that some pickups can have that transfer case and 3.42 gears. I've not seen an SUV equipped like that or don't remember.
I read somewhere once that it was 45 mph but it really depends on your gear ratio.
I've powered through some soft and deep Daytona Beach sand and some really slippery wet grass and 4LO got us out with ease. Can't think of a reason I'd ever need it on the highway other than to go off the road and maybe help someone get unstuck or cross a wide median.
GMCChevy
No, that's the 2 speed one which is more common then the single speed 4hi only.
petethepug
Michael
SoCal
*MP3010 Single speed *MP3023 Dual speed
*BW4485 AWD
Not sure what models the two different 4WD xfer cases are specific to but the AWD were the only option on 07 & 08 Esky & Denali.
9-14 Esky & Denali were AWD only with a few (uncommon) available with a 2WD option.
GM only did z95 Magneride on 09-14 Esky. 07 & 08 Esky were z55 autoride. All 07-14 Denali were z55 autoride.
*BW4485 AWD
Denali and Escalade Hybrids got Z95 too if memory serves.
My 9.5" axles came from RWD Escalades, one from an ESV and the other a shorty.
K
kirkdc
Thanks all. My concerns were not so much about having the 4 low - as most people mentioned its rarely needed. But I was concerned that the 4 Hi was a REAL 4 hi and not some kind of AWD set up...like in the Escalades and Denalis.
justafarmer
