OK to upgrade Bose speakers???
kozzy45
Found their website and sent them a message thanks!! Yes, I remember the ANC freaked out in my RAM and I had to disable it. I am assuming I would have to disable it as well in the Yukon. Do you happen to know how? Once I install an aftermarket AMP that will kill that feature anyways i believe. In the RAM, I just had to go into the headliner and unplug the microphones and that solved the humming issue. Not sure if it would be the same here. Thank yiou again all this information you are providing is very helpful.!!
I actually don't even think I have ANC. I don't have the build codes but looking at my headliner I only have the 2 mics above the driver and passenger. I believe those are just for the Bluetooth, I don't have any other mics anywhere in the headliners or the posts. Do you know if that is accurate? With RAM I could email customer service and get a full list of build codes, does GM do something similar? Thanks
on the new T2's I am not familiar on where the mics are i assume in the headliner as well, the wire will def be located on the amp harness as well.
kozzy45
Thanks , one more question, do you happen to know where the amp is located?
thanks again, and happy thanksgiving to you and your family
Kpwweb
Left rear cargo panel behind the wheelwell. Not the easiest to get to.
If you open the left rear fusebox door and stick your phone in there pointing to the front you will see it.
BadDaddy2003
