2023 tahoe OEM bose subwoofer enclosure upgrade.
porschegregg
My current build for my 2023 Tahoe RST.
I bought a 2021-2023 oem rear bose subwoofer box part number #84776627. The box is 4 inches deep where it molds to the gas filler neck inside the fender. Then it tapers up to 5 inches deep. I purchased a Kicker comprt 2-ohm 8-inch subwoofer with a mounting depth of 2 11/16 inches. I am powering it with an Audio Control amplifier — 300 watts RMS x 1 at 2 ohms. I picked the amp because it is small and the RMS wattage matches the sub, it also has an internal line output converter.
View attachment 419093View attachment 419095View attachment 419096View attachment 419097
cristiane
Does this Setup fit my 24 Tahoe RST.
SavageDad
I believe all 3 models, Regardless of trim level, have the same space in the rear driverside panel.
There's a guy that did a writeup on this under somebody else's subwoofer thread that I'm looking for right now that did just that. I think he used the 2019 Escalade unit with a 10" sub and swapped the sub out for a JL Audio or something and it all fit back there leaving him with decent thump, but looking totally stock.
kozzy45
Anyone try the JL Stealth box made for that spot as a direct replacement of the BOSE Factory sub? Thinking about it and trying to get some feedback on any results. Thanks
iamlegion
There’s a half dozen existing threads that answer this. Did you search for “stealth box” yet?
kozzy45
No, I hadn't, but since this was a thread about sub upgraded figured I'd ask the question...
RJStanford
For folk who’ve added a sub (considering the caddy box to do something on the cheap), what are you doing for an amp? Would like something that fits behind the trim.
2024 High country Tahoe
kerlyb
Just finished installing JL Audio Stealthbox in my 2023 Tahoe HC. JL recommends using their mono amp...XDM300. I went with Kicker CXA400...same specs as JL amp but $300 cheaper. Saved more money buying an "open box" unit on Crutchfield. I mounted it same as others have done on this forum...on top of sub box behind trim panel.
RJStanford
Thanks! I'm surprised that there's room, but that's good to hear. I will likely do the same.
brice715
